Author Topic: Ring and pinion question  (Read 1466 times)
Offline Groundpounder17
« on: July 05, 2015, 03:48:55 PM »
 Can anyone tell me the difference between the two different 3.91 ring and pinion numbers C8OW-4610-A and C8OZ-4209-A? Both are ford 3.91 ratio but why the different stampings?
MCA 103301
67 2+2 S Code Sept 66 San Jose
Re: Ring and pinion question
« Reply #1 on: July 05, 2015, 04:10:31 PM »
They may be one in the same. The "W" is a factory part number (aka engineering P/N), the "Z" is a service part number (aka dealer). The service number usually refers back to the factory P/N as the factory P/N has the dimension, tolerances, materials and source. The dual part ID system is a quirk of Ford. GM and Chrysler use a mostly "pure" (non-significant) number system, no decade, no year, no base number (even = RH, odd = LH), no dash number (sometimes).
« Reply #2 on: July 05, 2015, 07:44:26 PM »
Thanks, Jim. I would guess that FoMoCo 9 inch ring & pinion sets in 3.91 ratio are the same. Could a difference be the spline count?
MCA 103301
« Reply #3 on: July 05, 2015, 08:30:23 PM »
C8OW-4610-A - I think this is the Ford part number for the pin or pinion alone.
C8OW-4210  from my quick google is the ring gear by itself.
C8OZ-4209-A - Should be the ring and pinion assembly number.
Offline djjsc
« Reply #4 on: July 11, 2015, 07:51:33 PM »
krelboyne is correct.   I have an NOS C8OZ-4209-A Gearset (3.91 ratio); the crown is stamped C8OW-4210-A (43 teeth), pinion stamped C8OW-4610-A (11 teeth).    A 4th place "Z" in the PN syntax indicates service replacement parts.
