Author Topic: smog pump fan  (Read 1195 times)
Offline 266ks
smog pump fan
« on: March 09, 2014, 02:11:43 PM »
What is the best way to install the plastic fan onto the smog pump splines? It looks like it could be easily broken.  Thanks for any help
Re: smog pump fan
« Reply #1 on: March 09, 2014, 09:02:40 PM »
Center it on the center shaft and line up the bolt hoses. Place the pulley on the pump then tighten the bolts down slowly (using a cross pattern to do so) until the fan is seated.
That is what has worked for me ;)
BTW for others viewing this post
A site member has been working on an article for the Library here on rebuilding the Thermactor pumps and we're in final review :)
Offline 266ks
Re: smog pump fan
« Reply #2 on: March 09, 2014, 11:11:26 PM »
Thanks Jeff, I had thought that might work but wanted advice before I did.
