1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: jswoody on June 26, 2018, 11:11:56 AM
Looking for information for the best reproduction window gaskets made? I have read of some fit issues and would like any suggestions for best factory look and fit if possible. Any feedback is appreciated.
Which ones? Windshield and rear glass repro gaskets are prone to crack in the corners and have rubber color mis-match (corner pieces are either a lighter or darker black/gray color).
Other gaskets vary in quality. Best to be more specific.
Sorry, I am restoring a 1967 Shelby fastback and am changing all window gaskets and rubber. Any experience is helpful. There seem to be several different brands however I am not sure of the quality of any of them. In the perfect world I would replace them all with factory ford gaskets. Thank you for your input.
I have carpenter seals in mine. There were no issues with fitment. However, I found no manufacturer that makes the gasket like Ford did. The corners are assembled to the strips. I do have a couple tricks I'll pass along to you if you want to go PM or call. Let me know. I put both in my vehicle in less than an hour. I'll explain further about what to use to pull the seal in of you'd like.
-Keith
Front windshield and rear glass, do yourself a favor and go for NOS.
The Carpenter stuff is ok, but with any repro parts, it's easy to see differences with original. As cheap as the repro are, could always start with that and if there are issues that crop up, then decide whether or not to splurge on NOS.
+1 I used a NOS seal on my last one and could not believe how much better it worked.
I have used repop window gaskets, from various manufacturers, and I have yet to find any that are worth a damn. The worst are crap manufactured with licensing from the O.E.M. You'd think, with today's technology, that parts could be reproduced to exacting standards. Seems that "build them cheap so the profit margin is higher" is preferred to quality.
Even the Carpenter windshield gasket has issues. On the inside corners, it looks like release mold plugs that stick up. The rubber material is also a color mismatch as mentioned previously.
It's a lot of work to replace a windshield to swap out a cracked up gasket. Expensive for those that can't do it themselves also and introduces risk of chipping paint or doing damage removing/replacing the moldings.
There have been discussions before with using NOS rubber gaskets that have been sitting around for years/decades. Any feedback on those concerns?? The last thing I would want is to spend premium money on NOS gaskets/rubber only to have it deteriorate/crack/leak in a year or two.
I hear that a lot, but have not run into any issues before.
