Restoring - General discussions that span across many different groups of years and models => Suspension => Topic started by: Sunlitgold68 on July 28, 2009, 12:14:25 AM
Did 6 cylinders and small blocks use the same tie rods in 1968? Thanks
Books (MPC, Moog & Raybestos) say yes. No personal experience - but looks good
BTW - Welcome
All used the same in 67-69.
This is nit picking but it is a concours forum. Although tie rod ends are the same 67-69 (except 69 w/ DO spindles) the boots had different engineering numbers on the rubber.
Yep, that is right!
Do all tie rods have the same shaped boot and the ring at the bottom?
The 67/8 style have the metal rings. Not sure when the later style was introduced. They are interchangeable from a function perspective.
I think the ones without the ring came into play in 70. Scott Fuller makes a real nice 67-9 version w/o any engineering marks.(can't really see them once installed anyway)
I bought an NOS one and it has a different looking boot, but does have the "B" stamping on the bottom. I guess I should get the ring style boot and take the other boot off?
The boots can be swapped with relative ease.
That would be the 69's with the KKX or D0 spindles ;)
Looked at my original inner tie rods and the part # on the boot is in large #'s. Much much different than the NOS ones you see. It is a C8 number.
How do you get the old boot off and put a new one on? It looks like the ring is attached pretty good to the base.
To remove the boot, tap the bottom metal edge with a piece of wood or use a chisel if you don't care about re-use.
When you posted that 6 cyl and small blocks used the same tie rod in 68 does that mean that all 68's used the same tie rod 6 cyl,small and big block or did big blocks get a different tie rod?
All used the same regardless of engine size.
Regards,
Pete Morgan
Peter thanks.
I believe the metal ring boot was used up until very late 69 production when it was changed to the ringless rubber boot.Bob
