Restoring - General discussions that span across many different groups of years and models > Suspension
Original brake calipers - 1968 to 1970
(1/4) > >>
Anghelrestorations:
Not sure if anyone has studied or looked at this before, but figured I would throw this out here.  The original brake calipers that were used from 1968 to 1970 were a C8OZ-2B120-A (RH), and a C8OZ-2B121-A (LH).  I always thought it was unusual that Ford would only have one vendor and one design of this caliper as everything I have seen has been a KH (Kelsey-Hayes) design.  I dont think there is a Bendix front caliper unless I missed it.
I realize now that there is actually two different design original front brake calipers if you look closer - both are cast with the FoMoCo symbol and both stamped with what I think is a Kelsey Hayes date code.  These two are both from original Jan/Feb 69 Shelbys and match their build dates so assume they are original to the cars.  Curious if anyone has seen anything other than these designs during these years.  The caliper pictured on the left that I call the tear drop design dated 020KH9 is by far the most common I have seen.
20240505_185039 by Marcus Anghel, on Flickr
20240505_185140 by Marcus Anghel, on Flickr
20240505_185122 by Marcus Anghel, on Flickr
Bob Gaines:
FYI at least on the 69/70 Shelby the front of the caliper received a quick brush of semigloss /flat paint across the street side. This was to conceal flash surface rust from showing through the spokes of the Shelby wheel. I have not seen evidence of that being done on magnums given they do not show the calipers in the same way.
AJ:
I believe these to be originals from my late Feb GT500.  No revelation but perhaps date correlation useful in some way.
Adrian
Anghelrestorations:
Thanks Bob...yes good point.  My thought was to add that paint detail once the calipers were mounted on the car.
Adrian - do you see a FoMoCo stamping on those calipers as well?
AJ:
I?m pretty confident these hard to read marks are FoMoCo
[#] Next page
