Restoring - General discussions that span across many different groups of years and models => Drivetrain => Topic started by: A12pilot on January 31, 2018, 06:44:46 PM
Hi guys,
Got my motor back from the rebuild shop and so ready to drop it in! While going over dates and such, I'm seeing a stamping number on each head on the ends that are actually sequenced 116037 and 116038 respectively. This is the original motor to the car and original C8AE-H heads too. What are those numbers? Sequence numbers or something? Just curious.....
Cheers
Dave
Either one the same as your VIN? When Ford started out stamping all engines with a VIN workers sometimes would stamped the number on the heads rather than the block at some factories. Have two with different numbers might just be a screw up. Thinking that might be the first possibility since they are 6 digit starting with a "1"
Another possibility is a rebuilder stamping them for identification during a rebuild of the engine
Hi guys,
Cheers
Dave
Most likely a identification number stamped by the shop doing the most recent rebuild or one done previously . It is typically done to make sure a head goes back to the right customer. When Ford metal stamped a identification number on a head it was a VIN derivative and it would be on one head only.
Could be the sequential part of the VIN, let us know....
Thanks guys. Nope.... not the sequence of my VIN which is on the block ending 123426 as well as the transmission. Engine builder says he didn't stamp it, so not sure. My 390 was the only Ford FE in the shop. I know they are the original heads and never rebuilt either. Weird how they are sequenced only one number away from each other
Dave
Very neat and even application - IMHO rebuilders identification or accounting number
Agreed, often done my machine shops to track parts. Mr Gaines wins!
Hey ... I suggested that first !!! :) LOL
Was allot easier after pictures was posted
Great... thanks guys. The shop says they didn't do it, but who knows? Maybe the heads were rebuilt before? Makes sense. At least they are in sequence and look good. Thanks again!
Cheers
Dave
