Author Topic: A/C Radiator Support Hole(s)  (Read 1814 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: October 23, 2010, 10:20:12 AM »
My 66 Metuchen C-Code came without air.  The Original owner had a non-Ford aftermarket A/C system installed in 67 or 68 based on the date code on the York compressor.
I have removed this system and am rounding up correct dated components for a concourse factory system.
I need a clear picture of the hole(s) where the condenser hoses penetrate the radiator core-support.  Whoever installed this aftermarket system, was pretty hamfisted in making the hole and I'm sure it's not correct.
I am going to weld it up and PUNCH the correct hole in the correct location just like Ford did it.
66 Metuch Conv
Nightmist, Std Blu Int
Offline rockhouse66
Re: A/C Radiator Support Hole(s)
« Reply #1 on: October 23, 2010, 09:27:32 PM »
This is the lower hole in my 9/65 San Jose car, not sure how close this would be to yours.  Hope this helps.
'66 GT FB
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #2 on: October 24, 2010, 02:27:35 AM »
Here are the holes off my 64.5 june car with factory AC/PS
and the upper hole
The
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline bryancobb
  • 2009 Ridn' Around
« Reply #3 on: October 24, 2010, 08:34:47 AM »
Thanks a LOT guys!
Why was I thinking both hoses went through at the top?
66 Metuch Conv
« Reply #4 on: October 24, 2010, 12:19:44 PM »
Usually there are dimples in the metal where the holes are made when factory A/C installed.
