I have finished the rotisserie restoration of my 1969 Mach I & have the following leftover NOS parts for sale. Most parts are in their original packaging. Contact me at 541-971-2081 or BasileJimDandy@gmail.com if you have questions or want pictures.
Jim Basile
sold - dash pad black, w/AC C9ZZ-6504282-B1A $1,200.00
sold - front spoiler C9ZZ-63001A74-A $750.00
sold - gas cap flip open w/o twist cap assembly line C9ZZ-9030-C; Autolite $550
base) C9ZA-9A112-A
cap) C7ZA-9A107-B
sold - outside door handles, buttons, gaskets, etc. RH & LH C4DZ-6222404-A, C4DZ-6222405-A, C8TZ-9722454-A (x2) $300.00
sold - front bumper guards (w/attaching HW) RH & LH C9ZZ-17996-A, C9ZZ-17997-A $450.00
sold - rolled exhaust tips (pr) C9ZZ-5255-C, eng) C9ZA-5C262-E $400.00
sold - front grill C9ZZ-8200-A, eng #:C9ZB-8150-B $400.00
sold - Starter Solenoid Relay Switch B6AZ/C9AF-11450-A, eng) C7AF-11450-A1 $325.00
sold - door sill/scuff plates (pr.) C9ZZ-6513208-A $300.00
sold - gas cap flip open w/twist cap F3ZZ-9030-C $300
base) C9ZA-9A112-A Autolite
cap) C7ZA-9A107-B Autolite
sold - front parking/turn signal light assembly Right zinc dichromate C9ZZ-13200-A $300.00
price varies w/choice of lens: 1969 NOS, 1970 NOS, 1969 used, 1970 used
sold - front parking/turn signal light assembly Left zinc dichromate D0ZZ-13201-A (3-prong & same mounting bracket as 1969) $300.00
sold - door speaker (x2) D1AZ-18808-F $250.00
sold - backup light assembly RH C9ZZ-15500-E $250.00
sold - backup light assembly LH C9ZZ-15500-F $250.00
sold - tail light lens w/stainless trim (pr) C9ZZ-13450-A $250.00
sold - shifter handle knob (black T-handle) D0OZ-7213-D $200.00
sold - shifter stalk/lever (chrome) C9ZZ-7210-C $175.00
Battery tray (group 24) C7ZZ-10732-D $155.00
sold - tail light lens bezels (pr) C9ZZ-13489-A $150.00
Speed/Throttle Control kit (Economy Cruise Control) C8OZ/C9AZ-9B742-A $150.00
sold - carburetor spacing plate, 1″ aluminum C4OE-9A589-A $100.00
Engine Oil cap, breather 68/69 Autolite twist-on w/metal 90′ breather hose adapter 289, 302, 302 Boss (Metuchen), 351W, Black, C8AZ 6766-A $125.00
sold - outer headlight (chrome) bezel (x2) C9ZZ-13064-A $125.00
sold - side marker light bezels (x4) C9AZ-15A440-A $125.00
Ford speedo cable for the 69 mustang with the 3 speed m/t and automatic transmission C9ZZ-17260-C $110.00
sold - stripe kit - gold/white - complete set (11 pcs) C9ZZ-6320000-F $100
sold - A/C master vacuum mode selector switch (mounts below radio) C9ZZ-19B888-A $100.00
sold - hood pin dowel (x2) C9OZ-16929-A $100.00
sold - side marker/light bezel lens (x2) rear, red C9AZ-15A201-C $100.00
sold - side marker/light lens (x2) front, clear C9DZ-15A215-C $50.00
sold - AC/heater blower switch assembly C9ZZ-19986-A $100.00
sold - front parking/turn signal light lens Right (1969) C9ZZ-13208-A $100.00
sold - front parking/turn signal light lens Left (1969) C9ZZ-13209-A $100.00
sold - front parking/turn signal light lens Right - near NOS (1969) C9ZZ-13208-A $50.00
sold - front parking/turn signal light lens Left - near NOS (1969) C9ZZ-13209-A $50.00
front parking/turn signal light lens Right - near NOS (1970) D0ZZ-13208-A $25.00
front parking/turn signal light lens Left - near NOS (1970) D0ZZ-13209-A $25.00
front parking/turn signal light lens Right (1970) D0ZZ-13208-A $75.00
front parking/turn signal light lens Left (1970) D0ZZ-13209-A $75.00
sold - wheel lip molding rear LH (fastback) C9ZZ-6329165-A $100.00
sold - neutral safety switch FMX C9ZZ-7A247-C $100.00
sold -inner headlight grill door/bucket assembly RH C9ZZ-13064-B $75.00
sold - inner headlight grill door/bucket assembly LH C9ZZ-13064-C $75.00
MUSTANG trunk letters w/o pins (double sided tape), complete set D1ZZ-6540282-A thru G
(A=M, B=U, C=S, etc.) $75.00
sold - backup light lens (x2) C9ZZ-15514-A & backup light lens gaskets (x2) - fits between lens & housing C5ZZ-15510-A $75.00
distributor Primary Wire (Autolite w/yellow rubber boot) C7VY-12216-A, Motorcraft: DW-34 $50.00
sold - shifter knob button – left-side release button (chrome) C8OZ-7C488-A $50.00
Engine Fuel filter 200, 250, 289, 302, 351W, 351C, 390GT(69 only), (GT350 68/69) Autolite, w/rubber hose & clamps $50.00
sold - wheel lip molding rear RH (coupe/convertible) C9ZZ-6529164-A $50.00
sold - backup light lens gasket fits between valance & housing C7ZZ-15533-A, eng) C7ZB-6328073-A $50.00
sold - dipstick 351 Windsor (in wrapper) C9OZ-6750-A $50.00
brake light switch (power brakes, disc or drum) mounts near steering column C9ZZ-13480-B, cast/eng) C9ZB-13480-B, Motorcraft SW-864 $49.00
windshield washer bottle lid $25.00
Distributor repair kit - contains rotor, points, condenser $40.00 ea
distributor rotor (2 avail) B7A-12200-A $15.00 ea.
side mirror, knob replacement/repair kit LH; earlier version chrome stem only D6AZ-17B718-A $35.00
side mirror, knob replacement/repair kit LH; later version black stem & black mounting cone D6AZ-17B718-A $35.00
wheel lip molding screws 381671-S $28.00
Engine Oil cap, breather 68/69 Motorcraft twist-on C8AZ 6766-A $24.95
contact set (aka, points) Motorcraft (3 avail) B8Q-12171-A $15.00 ea.
sold - Window Crank Knob white (x2) D1AZ-6523352-D $20.00
sold - AC/heater blower switch assembly C9UZ-19986-A $20.00
sold - Radiator hose upper C3DZ-8260-J $20.00
alternator pulley for C6AF-10300-F alternator C5AZ-10344-K eng) C9AF-10A352-B $20.00
fuel filter w/ clips & fuel line Motorcraft D7TE-9155A $20.00
sold - Window Crank Backing Plate Nylon (milky or translucent white) (x2) C8AZ-6223370-A $20.00
sold - Radiator hose – lower C3DZ-8286-F $20.00
sold - door lock knob grommets (x2) D0DZ-6221999-A $20.00
front seat pivot repair/reinforcement bracket (fix) LH/RH D7ZZ-69618C46/7-A $20.00
sold - condenser Motorcraft (3 avail) C9AZ-12300-A $15.00 ea.
sold - Rear license plate light lens C4AZ-13564-A $20
Brake master cylinder cap (assembly line with ESA spec & 2 breather vents on edge of cap) C9AZ-2162-A $200.00
Brake master cylinder cap rubber gasket (w/square tips) C7AZ-2167-B (replaced by D1FZ-2167-A) - Bendix PN 2225441” $40.00
Windshield wiper metal blades & rubber inserts Trico 16″ RF-16 $150.00
sold - hood pin plate (polished stainless steel) (X3) C9OZ-16N782-A $30.00
Oil Filler/Breather cap grommet (for 90′ elbow); same as round, not shaped PCV grommet C8AZ 6A892-A $20.00
Oil Filler/Breather cap elbow (90′, 5/8 x 5/8) C8AZ-6766-B $20.00
sold - air filter (Ford FA41, Motorcraft) B7SZ-9601-A $19.95
sold - bumper fender to cowl side (x2)(mounts on fender near cowl) C9ZZ-16758-A $14.00
sold - Retaining Clip Air Conditioning center register/vent to Duct (x2) C7AZ-14570-A $5.96
gas pedal screw/pin C8OZ-9873-A $5.14
Automatic transmission vacuum modulator (to engine) (ribbed) hose - 1 1/8" long, 7/16" OD C9OZ-7B087-A $10.00
