1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: 67BB390 on February 11, 2024, 08:37:48 PM
Good place to get one, Appreciate any help.
No one makes one that is like an original. So you are left with rebuilding an original or a NOS and having it rebuilt since the original rubber parts will not hold up against the new gases with grain alcohol in them.
Remember if your going all the way make sure the numbers are correct and acceptable date is on the base
(https://www.concoursmustang.com/forum/gallery/20/6-120224131111-200921130.jpeg)
(https://www.concoursmustang.com/forum/gallery/20/6-120224131112-200922121.jpeg)
Will send a PM
Will send a PM
+1 with Jeff's comments . I would like to add a few things. My comments are meant to be helpful not only for the original poster but for others that may be reading. First off it is always best to go for as good as you can get. Depending on your expectations not all of the details for a given part may not be necessary. For example if you were trying to build your car to concours show quality yardstick regardless of if you were going to show it or not then it is important to understand what is expected of your cars condition for a given concours class. In the case of the fuel pump the button top style fuel pump is the number one priority because it is the most visible and notable detail and is what is expected. A few other details that are great to have but not necessarily relevant are the CARbureTER trademark which was on early 67 production and the CARTER trade mark which was on later 67 production. In MCA trailered concours for example which has a high bar for originality and is a judged class the trademarks are not looked at. The right trademark is nice to have but not necessary. The flange number and date code are secondary also and again nice to have and strive for but not only hard to find whats needed for a given car but not required as they those things are not looked at in trailered concours class. Throughbred class is the only class that those details are expected to be exact and original In that class every single part has to have proper date codes and numbers on all original tires,belts,batteries etc. with absolutely no reproduction parts . I thought it best to comment because it is our goal to help and not discourage . The original details are important to share but can seem like a unsurmountable mountain to climb when added to a list of others. Hopefully by putting some of these things in perspective along with information and advice given will help one decide what is best for each individuals situation.
Does this look like an original pump? This is on my signature car.
Looks like its a Carter possibly from the period. Can't be any more certain without a cleaning and look at the casting and stamped details
Thank you Jeff. Added to the list!
Given it has what looks like a 5/16 inlet to me and the button top at the very least makes it a vintage 1967 variety. Consequently it will no doubt have ether Carter or CAR bure TER trademark.There is a good chance therefore it is original to the car unless known as a replacement otherwise.
Thank you Bob. I will clean up the side to verify trade mark. The pump does not work, so I will be pursuing a rebuild service through Fred.
