1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: 1965 t5 on October 03, 2016, 04:19:33 PM
Hi all - I know this topic has been discussed a lot but my question is relative to what is actually supposed to be visible on the panel. Most of the lettering/ codes were under the paint. Is it worth duplicating those codes if you're just going to paint over it? Can you see the grease pen detail through the paint if properly done? Also, are there codes over the paint on that panel or on the x-brace underneath the radiator panel? Thanks!
The lettering is typically not visible under the paint. Is it worth doing? That is a personal decision.
Thank you for that reply. Is there any lettering that should be visible on that panel or the lower x-member on front of frame?
Probably depends on the plant and if you found any on your car originally. General concours advice is if you didn't find it on your car, don't just add to your car what you see on other cars. I don't think there are any standard marking found on all cars....
Probably depends on the plant and if you found any on your car originally. ............
+1 All depends on the plant and year your asking about. There were IMHO marks that were pretty standard and those that likely were only placed on a specific car. These only become apparently after looking at allot of cars.
As often stated on this site, your original unrestored car is the best source for any marking or detail (honestly compared to acknowledged common practices of the time) if those are missing, replaced or gone we can only offer an educated guess based on available details
