1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1966 Mustang => Topic started by: socalgt on June 21, 2017, 07:48:15 PM
Not very easy to find the correct size fuel filter for an original 4100.....what is the thread size of the inlet on an original carb? Mine may be partially stripped and I don't want to repair it until I'm sure what size the original filter threads are. Wicks filter is wrong, purolator, etc. I see one advertised that indicates it is for original carbs only, so I'm assuming that would fit.
Thanks...
The thread is 1/2-20 and it's the same thread that's used on 64-65 carburetors for fuel input. I get Motorcraft filters from Amazon, FG-15, C5AZ-9155-B. They may not be the correct color, but they work fine. Watch e-bay for NOS.
Thanks.....there's just enough decent threads left for the filter to be attached securely. It turns out I had the correct filter, but it was so loose in the first half of the inlet I thought it was too small.
