1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: 67gta289 on February 27, 2020, 06:40:01 PM
I have a line on a set of C7ZZ-15511-B and C7ZZ-15512-B which according to the MPC was introduced on 4/8/1968.
My car (December 66) should have the -A version.
The backup light document by Marcus (link below) says that the difference was only in the light bulb socket, and there are no external visual differences.
http://anghelrestorations.com/uploads/3/5/1/2/35122002/back_up_lights_v1.1.pdf
Does this mean that the bulb is a different type as well? If not, why would Ford continue to carry both versions for service?
No, same 1156 bulb.
The 1157 bulb will fit bulb and work, but the correct bulb is the 1142. The difference is the 1142 is a single filament and the 1157 is a dual filament (Stop and Turn Signal). I did not do a deep research of all years, but it was used in 66 to 68 and probably many more year of first generation Mustangs.
Thanks for the replies.
Back to the original question, restated:
If the only difference between the two was a change do the light bulb socket, and if the actual bulb requirements did not change, and if there is no visual difference between the two, then why didn't the revision B part replace the original revision A, instead of carrying both with a running change date? I suspect that there has to be something more...
