Restoring - General discussions that span across many different groups of years and models => Processes, Products & Techniques => Topic started by: Brian Conway on February 21, 2021, 01:28:50 PM
Title: Corrosion Removal
Post by: Brian Conway on February 21, 2021, 01:28:50 PM
Is there a product or method that will remove the black stuff from the shield with out damage to the original finish ?  Thanks, Brian
Title: Re: Corrosion Removal
Post by: Coralsnake on February 21, 2021, 04:18:16 PM
There was not finish on that part, it was bare steel. You can neutralize the corrosion, but it will likely return
Post by: J_Speegle on February 21, 2021, 04:23:38 PM
Brian is that surface pitted also?  If so your better off just replacing with one that does not have the damage IMHO
Post by: Brian Conway on February 21, 2021, 05:03:38 PM
interesting.  I've seen this black stuff before.  Usually a part of the general rust/corrosion package.  It's a surface situation that can be chipped/scraped off with a utility knife.  I have heard and read that ' bare steel ' is the usual and was a bit surprised at the appearance of this shield.  I had not though of replacing.  I didn't know that was an option ?  This shield may have been a replacement ?  Part is new to me and is for a C5AW-C Daytona pinion support.  It does have a yellow dab on the side.  Thanks for the help.
Post by: preaction on February 21, 2021, 05:10:24 PM
Mabye evap o rust for a short time enough to remove the  " color " then Boeshield.
Post by: Brian Conway on February 22, 2021, 12:30:48 PM
OK a bit more cleaning.  Appears to be all steel.  Thanks, Brian
Post by: Coralsnake on February 22, 2021, 07:25:12 PM
Very nice now
Post by: J_Speegle on February 22, 2021, 07:40:39 PM
Much improved. Of course if the light pitting makes a difference a swap is possible as mentioned. Just have to get a better one
Post by: RoyceP on February 22, 2021, 07:49:51 PM
The stamped steel shield is simply pressed on. You can find a better one from a cheaper application and swap that part easily.
Post by: 69bossnut on February 27, 2021, 03:17:11 PM
The shield was serviced. I have bought a few over the years but don?t remember the part number.
