Author Topic: Original front seat belt hardware  (Read 1307 times)
Offline ChrisV289
« on: May 30, 2017, 05:19:57 PM »
Does anyone have a picture of original seatbelt hardware on a fall of 64 built San Jose car?
2009 V6 Mustang Coupe
Offline tvor
Re: Original front seat belt hardware
« Reply #1 on: May 30, 2017, 09:22:48 PM »
Here are pics of my hardware.  My car has a door tag build date of September 1964.
BTW, go by the dimensions written.  The photo is not a direct shot and makes it look like they are ~1/16" bigger
Hope this helps,
Kelley
'65 Coupe, built in San Jose.
289 CID with C4 trans.
Door plate date of 9/11/64
Original owner - mom
Second owner - me!
Offline ChrisV289
« Reply #2 on: May 31, 2017, 12:49:01 AM »
ok so this is what I currently have on my car.  The bigger washer is thin and goes between the seat belt and the top of the anchor bolt.  The smaller washer is actually thick and is between the seat belt and against the carpet or the rocker panel depending on which belt you are looking at.  Is this the correct setup?
« Reply #3 on: May 31, 2017, 10:29:59 AM »
Chris, have you checked the assembly manual?
Offline ChrisV289
« Reply #4 on: May 31, 2017, 02:00:30 PM »
No, I don't have the interior assembly manua as I never had an issue with the interior until now.
« Reply #5 on: May 31, 2017, 04:10:39 PM »
Seat belts are documented in the 65 Mustang Body Assembly Manual, page 45 (N5-8715).
jim
« Reply #6 on: May 31, 2017, 05:22:06 PM »
Sorry no pictures of the hardware removed but may these can help in some way
In the first picture the plastic end has come undone from the rest of the assembly
Offline ChrisV289
« Reply #7 on: May 31, 2017, 08:07:32 PM »
jim
I only have the chassis assembly manual.
« Last Edit: May 31, 2017, 08:23:39 PM by ChrisV289 »
Offline tvor
« Reply #8 on: June 01, 2017, 09:46:46 PM »
I only have the one large washer and I installed it between the carpet and the belt.  I know mine to be a 1 washer set-up because mom (and I) are original owners and the car had never been restored until recently.
Kelley
Second owner - me!
