1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: mason1958 on September 17, 2017, 06:55:47 PM
Does anyone have a picture of the air cleaner assembly for a 3-17-69 Methuen car ?
Thanks Mason
Here you go. Have other examples from other plants. Believe they all used the same air cleaner that year. Ignore the PO added extra decals and emblems ::) Bottom example is of a "restored" car
9T1022xx
(http://www.concoursmustang.com/forum/gallery/8/6-170917221641-8706954.jpeg)
9T1515xx
(http://www.concoursmustang.com/forum/gallery/8/6-170917221639-87051498.jpeg)
9T1565xx
(http://www.concoursmustang.com/forum/gallery/8/6-170917221643-8707749.jpeg)
Thanks Jeff. So a Mach 1 had a heat sheild ?
Mason
Mason
All engines had a heat shield by 68 on Mustangs. Top example is just missing it. And to make things tougher 69 heat shield is different from 68 :( and very difficult to find.
I did not think that 1969 S codes used a metal S tube. Thought that they were paper? Was it a Metuchen thing? Have only seen a couple of 1969 Dearborn cars with 390-4V.
Believe the air cleaners, S tubes and heat shields were pretty much all the same across all plants due to federal emission standards by 69.
It appears that what Ford shows is the reducer at the snorkel and the paper/tin foil tube but can't explain why the one example has what appears to be a 68 style or 428 steel style S tube. The later MPC shows that a number of 69 engines changed to paper/tin foil tube in Oct production but does not show that change for the 390 4V. Not sure if its correct or a mistake but the one example would likely have been built after Oct
The use of the paper tube may have somethign to do with the change in the heat shield design between 68 and 69
