1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: 7Lscjracer on August 02, 2013, 02:09:58 AM
Are there plastic inserts to accept a screw surrounding the speaker hole to mount either the speaker or the grill, or do the screws just go directly into the sheet metal?
Grill screws are readily available, but I can't find any info on the speaker mounting screws, and I need a set of 8 thanks.
No plastic thread inserts that I can remember
I can only speak for my SJ Mach1. Screws go right into the sheet metal.
Thanks all, that will make it easier to repair my doors.
Unlikely I'll find a factory speaker door pair, but now I can use plain doors and make the cutouts.
I see there are templates on eBay.
What I really need are just the section of the door in that area to stitch into my original doors.
Doors rusted out underneath are usually still good where the speaker goes, and are all I need for donors.
The speaker hole looks like it was cut with a dull butter knife. 8)
hi door speaker cut out as for the door panels i see marking on the back of the panels to punch out ..... but my question is how is the carpeting cut size wize is the bottom cut off ? work a april 1 69 nj built car....
plus how was hole cut into the door pic would help
Thank you
Guess your working on a Mach I or a Grande?
Carpet was normally cut off following the back side as a guide. So its (for lack of better words) is a whole with the bottom edge open /no door panel or carpet edge
Will look and see if I have some pictures of that area and a door panel and post.
Had to look into my 70 examples before I found a Mach I or Grande door with panel in place but speaker and grill removed
Sorry they are not the best but the focus at the time the picture was taken was not this specific detail
(http://www.concoursmustang.com/forum/gallery/7/6-290717220844-76882180.jpeg)
(http://www.concoursmustang.com/forum/gallery/7/6-290717220845-76892221.jpeg)
Here's a template for cutting the door:
http://www.ebay.com/itm/69-70-1969-1970-FORD-MUSTANG-MACH-1-DELUXE-DOOR-SPEAKER-TEMPLATE-/382180440492?hash=item58fbbab9ac:g:N70AAOSwzqFY8oHK&vxp=mtr
I haven't been able to find the screws for securing the speaker to the door.
Last I checked that part number wasn't available from AMK.
Not sure if the grill mounting screws are black or silver colored either.
Repro grills look pretty good from the front, but don't have the paper and foam strips on the back of the grill surprise, surprise.
Silver - look to be zinc or cad not chrome
Thank you yes is a mach 1 so the grill cover is onto the carpeting when screwed down ont the top and sides so the only door tempate is a ebay one
Thank you yes is a mach 1 so the grill cover is onto the carpeting when screwed down on the top and sides
Don't understand. There are four screws one at each corner - that have nothing to do with the carpet
The carpeted section of the door panel is cut on three sides, top, front and rear edges leaving the bottom of the cutout open. No carpet or vinyl trim visible below the speaker cover
so the only door template is a ebay one
That template that is being sold is for cutting the door if your adding speakers or have replaced the door(s) during the restoration not for the door panel.
Is it the only one? Sure there are other ways to get that template 7Lscjracer was just offering one he had found
The grill pins the carpet down at the top and sides
If you look at the grill the bottom is thicker so it reaches the door metal and the sides and top are thinner to accommodate a little perimeter of carpet underneath
If your grills are the same thickness all around then they're for standard door panels
A few pictures to help
(http://www.concoursmustang.com/forum/gallery/7/6-310717155144-7690263.jpeg)
Holes for speaker and holes for grill mount/attachment
(http://www.concoursmustang.com/forum/gallery/7/6-310717155146-76911098.jpeg)
Appears that something has been dropped on the top edge of the speaker holes - reason why its not perfectly oval ;)
(http://www.concoursmustang.com/forum/gallery/7/6-310717155147-76921115.jpeg)
Thank you for the pic now i can do the job correct thank you all
Does anyone know if there is a stencil or video on the best way to cut out the area for the deluxe speaker grills on the deluxe door panels. I do not have an old one to measure and the new door panel does not have it marked. Thank you very much
I suppose that you already saw the ad for the template from a couple of years ago on EB*y. Link is dead but maybe they are still offering them. Don't recall if I saved a copy of what was posted on that site.
Maybe someone out there has a door with a factory hole that can share details. I guess you already saw the examples posted in at least one of the other threads. Will add your post to that thread, it's the largest one on the subject. Will do this to keep all these questions and help together. It is the one that focuses on 69 Deluxe interior applications
