1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: 1967 eight barrel on January 29, 2016, 01:11:10 AM
I am wanting to replace the sealer that was used I assume to keep the fenders from making noise with the unibody under high stress loads. I remember it being about an 1" wide by 1/16 thick and appeared to be similar to the tar wrap I have seen used on AC expansion valves.
Does anyone know what we are using in the restoration of the vehicles and where it can be obtained?
Thanks, Keith
Thanks, Keith
Butyl tape or strip caulk . npd sells both. black ,gray strip caulk or you can mix the two for a dark gray.
I have strip caulk. They offer the tape version at NPD? I was at the FL store Friday and he looked at me like a deer in the headlights when I asked.
-Keith
+1 on the black 3M strip chalking. Normally take 3-4 strands, work them together then stretch them until the cord is the diameter of a lead pencil then apply it to the surface. Press it to form a strip that is now wide and thin then install the fender.
You don't want to leave all the strands individuals since you can often see this detail from the wheel well side :( Doesn't even look correct from that angle
Remember once applied and all the panels in place its rarely seen from the engine compartment side other than a bit around the VIN cut out in the fender
NOTE: Split off from another thread concerning gas tank to body sealants
http://www.concoursmustang.com/forum/index.php?topic=3145.new#new (http://www.concoursmustang.com/forum/index.php?topic=3145.new#new)
When applied to the gas tank and fender area (SJ Mar) how much should Goosh out? Yeah, Goosh is a technical term!
Gas tank typically ..........................
Fenders often none IMHO was not covered. Every once in a while you might find a car where the end of the strand slide out but from the tens of thousands I've seen this was not the norm. Many of the picture threads of unrestored 67 San Jose and even 68's here on the sight will provide you with some examples
If its seen, its typically at the VIN cut out since the worker may have applied it fairly straight down the edge of the inner fenders not compensating allot for the cutout
Have tons of unrestored pictures where no sealant is visible but no reason to show them. Here are a few of the examples when the material was visible from the hood is open.
Product and color of the product. Once the product used is exposed to air and sun for many years if turns a lighter shade and becomes dry and chalky
In this freshly prier off example (removed from the location where the green arrow is) you can make out the chalky upper edge that was exposed and over time it continued to spread through the sealant drying out from the exposed edge inward. The Blue arrow shows an area not yet affected showing the original color of the product used
This example also provides an idea of how much product made up the strip applied to the inner fender panel
(http://www.concoursmustang.com/forum/gallery/9/6-291017221010.jpeg)
Here is an example that has been exposed for a while. Color has changed like the edge of the product shown in the example above.
Its bone dry all the way through as you can see as I scrapped through it and tried to pry it up like the other example above.
(http://www.concoursmustang.com/forum/gallery/9/6-291017221422.jpeg)
So if you want to include a "blow out" or "smooch" :) somewhere in the engine compartment here are some original examples. Remember that exposed sealant will collect dust and dirt as well as micro fiber towels used for cleaning and plenty else
Took a bit to find these since as, mentioned allot of cars had no visible sealant from the engine compartment view. Hope these help
(http://www.concoursmustang.com/forum/gallery/9/6-291017223811.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-291017223827.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-291017223841.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-291017223857.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-291017223912.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-291017223930.jpeg)
Remember that the product you use can be seen from the wheelwell so if you try and cut corners it may be uncovered there. Here a builder choose incorrectly to just run three small diameter/thin (out of the box) strips of strip chalking rather than work the strips together into one strand and apply it like originally done
(http://www.concoursmustang.com/forum/gallery/9/6-291017224437.jpeg)
You even managed to get the color of my car in one of your examples. Well done!
And thank you!
I know this is an old topic, but I've wondered about the large amount of sealant squeezed out from under the fender on my San Jose '68. I guess it is normal, if not excessive. As far as I can tell this car has never been apart. I want to clean up the engine bay, leaving it as original as I can. But, I'm not sure what to do with the sealant other than maybe leaving it alone.
Leaving the sealant original means not touching it . Re doing /restoring other aspects of the engine compartment may render leaving the sealant alone a non issue . If everything else is cleaned up (restored ? ) the sealant and it's patina may not look consistent with everything else. You will have to weigh the plus and minus's yourself and make the decision that best fits your situation. Best of luck with your decision.
As Jeff tried to explain, the sealant was done like a lot of things on the assembly line - inconsistent and often sloppy. I wouldn't fix it, it's not broken.
