1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: 1967 eight barrel on July 06, 2018, 10:26:43 PM
Title: Steering box pitman arm centering method assistance.
Post by: 1967 eight barrel on July 06, 2018, 10:26:43 PM
I have noted with the vehicle up on jackstands that I seem to have almost one more turn from one side to the other of the wheel. Is there a simple way to re_
-key the location so right and left has an equal amount of turns right to left. Remember, big block, power steering with headers.    -Keith.
Title: Re: Steering box pitman arm centering method assistance.
Post by: 67gtasanjose on July 07, 2018, 07:13:45 AM
It is centered by adjusting the Power Steering Control Valve, threaded onto the steering center link also called a drag link (note: There should be a roll pin inserted into a slot under the band clamp). The only EASY WAY I know to do this would have been to make a note of how many turns it took to remove it and threading the restored valve back on the same number of turns.
The process would have to be a bit more involved when doing it from scratch, I have never done that before. Interesting aspect when beginning from scratch would be complicated a bit more when you are using a restored assemblyline IDLER ARM. Perhaps when the idler arm was new, that was the beginning point in making this adjustment but once any bushings have been replaced, where do you begin?
I've made a quick search of the Ford Service Manual and did not find any help there. I do know that ideally, the steering box would be centered first and then the drag link and idler arm as an assembly including the PS control valve/drag link would need centered next. The assemblyline style idler arm HAS to be centered properly too if it has been apart or the torsion of the rubber bushing will cause the steering to pull against the direction the rubber is twisted...It isn't rocket science but it isn't at all easy especially if the car has already been assembled incorrectly first (getting all of it back off the car to start over will make this a horrible, horrible job)
I am hoping to hear how others have done this from scratch. I do alignments as a trade and I have a few ideas on how to start from scratch but perhaps there are easier ways than what I have come up with in my brain. This has been a future "check box" that I have not checked yet. I know I took notes when I took it apart but I also know I changed that PS control valve twice before too so I wanted to get this right BEFORE I add PS fluid and tighten everything up and BEFORE the engine and fenders and such go on the project.
Post by: ruppstang on July 07, 2018, 09:01:15 AM
I have several cars to look at so I use a average number of threads in to the housing. Then adjust it to center with the tie rods adjustments. It might not be the most correct way but has worked for me.
Post by: 67gtasanjose on July 07, 2018, 03:06:32 PM
I do alignments as a trade and I have a few ideas on how to start from scratch.
This method should work on at LEAST 67-70 model years. Perhaps similar for other vehicles with the Ram Assist Power steering systems where the control valve is seperate to the Center Drag Link.
The ideas I have in mind might seem complex unless broken into steps. Alignment work on any car, is nothing more than geometry, complicated by being muti-dimensional. With that in mind,  so many of the things I might take forgranted as knowledge could seem condescending if written out or explained in what another might feel as too "detailed". Hopefully, these steps don't come across that way:
Step-1: Set the gear box & steering column as "centered"
*With the pitman arm disconnected from the PS control valve at the ball socket of the control valve, count the number of turns of the steering wheel it takes to go stop-to-stop and divide by 2. Turn the wheel back to "center" with exactly half the number of turns.
*If the steering wheel isn't upright and centered, get this corrected before going on to Step-2. The easiest solution here might be simply remove the steering wheel and centering it inside the car. Double check your results before going to Step-2
Step-2: Set the idler arm straight ahead
*If using a RESTORED assemblyline Idler Arm (new bushings pressed into an original part), it may be a good idea to leave the nut joining the two halves of the idler arm loose for this step. If NOS, OE Ford Service Part, it SHOULD be already correct. (Remember that Ford Service parts might look the same from other Ford Carlines so be 100% sure yours is a genuine Mustang Idler arm or that it has been corrected to work on a Mustang. More info about this detail in other threads). Assuming you have a RESTORED Idler arm, bolt it down to the frame (with a loosened nut joining the two halves) and tighten this particular nut ONLY after setting the idler arm to align with the centerline of the vehicle or after full vehicle is assembled and a road test confirms no other issues. DO NOT FORGET TO COME BACK & TIGHTEN if you choose to leave this loose at this time. I personally, would leave this loose until after the whole front end alignment work is done, tightening this particular nut, again... ONLY after confirming on a test-drive that NO OTHER ISSUES ARE PRESENT. Individual's choice if you think you can visually "see" or "measure" the centerline of your vehicle or not.
ADDED NOTE: Many aftermarket idler arms are NOT made like Ford made them, these are not as fussy in this particular step.
Step-3: Adjust the depth of threading the center link into the control valve
*THE HARD PART*
*With the control valve threaded in approximately 20-turns onto a bare-naked center (drag) link, (the assist ram and tie rods set aside for now off the vehicle), steering wheel locked in the straight forwards position (steering box centered already as a result of Step-1), loosely attach the Control Valve & Center Link as an assembly, without torquing down for ease in removing again if or as needed. Do not have the inner tie rods attached yet. The tie rods will be in the way if they are there, it would be best to remove them completely to keep them out of your way if these were already attached before this step.
*Confirm the "locked steering wheel" has not moved, visually look to see if the Idler Arm is in alignment with the centerline of the vehicle. The centerline of the vehicle runs from front to rear of the unibody structure and is an artificial point of reference.  Adjust the turns of the center link into or out of the control valve as needed until the Idler Arm VISUALLY looks to be aligned to the centerline of the vehicle.
*NOW THE FUN PART! The fine-tuning: Once you feel you VISUALLY have the Idler arm centered, it SHOULD be checked for accuracy by taking measurements. Three-Dimension Geometry can be tricky but let's change our thinking to two-dimension and we can get this one down too with a simple tape measure. FIRST, assure yourself that the center/drag link runs parallel (crossways) to the body. If you have the WRONG Idler Arm or Pitman Arm, this step will not help until that is corrected. Remember, many items that LOOK RIGHT will bolt into your Mustang but not all that LOOK RIGHT are correct so this step should prove or disprove the correct pitman and Idler arms. So, with the center/drag link confirmed as parallel crossways, take a measurement from the center of the hole the Left Inner Tie rod would be inserted and measure to the center of the slot where the lower control arm mounting inner cam bolt. Check the right side using the same method as the left side. These numbers must be checked and confirmed in identical techniques and they ought to be 100% identical or again, adjust the center link or drag link as needed.
Once everything has been confirmed to be as close as possible, torque all fasteners and install cotter pins and find something else to do that has a little fun associated with it! (Some people suggest adult beverages, others might take the spouse out to dinner. Some might do BOTH!)
Ideally, these numbers and measurements should be double checked and in my opinion, all test-fitting and any adjustments needed to the number of turns on your PS control valve to Center Link, ought to be done very early on to the final assembly, essentially on an almost naked shell of a car, with no suspension components, no engine or transmission. Nonetheless, anyone might discover this demon the O.P. brought up at different progress points so these steps may assist you at any point of discovery. Getting this center link RIGHT early on will prevent a whole lot of later issues in overall satisfaction of the way your Mustang or Shelby handles while using the classic suspension parts.
I may need to edit this a bit but I need to get back out to the garage and get something done on my car so I hope this helps some people see the picture better at least.
Post by: Bob Gaines on July 07, 2018, 07:05:42 PM
Good job. This should be very helpful thank you for the effort .
Post by: 1967 eight barrel on August 11, 2018, 08:17:30 AM
I just noted your reply, Rich.  I am not running a factory idler and Rode did the rebuild on my Control valve/drag link. He says it needs no further adjustment.....
However, I did note that the incompetent mechanic that aligned the vehicle didn't adjust the tie rods evenly, by almost two inches on one side.
The tell-tale should have been the fact that I went to pick up the vehicle and the idiot left the lower control arm adjustment bolts loose and when I backed it out to put it on the trailer the arms popped and I had to leave the vehicle for him to do the job again.
Anyway, this is a good starting point and I will use it and assist the tech, as he isn't going to be happy doing all this. Parts changers hate to do anything that requires heavy thought and some preparation.
        -Keith
