Author Topic: Thermactor Cylinder Head Plugs  (Read 780 times)
Offline Myfo28
« on: April 16, 2018, 12:49:59 PM »
Looking for 8 each cylinder head plugs part #C6AZ-6052-A for 1970 428 CJ.
1970 Mustang 428 CJ Convertible
Ravens Black
R Code
Online krelboyne
Re: Thermactor Cylinder Head Plugs
« Reply #1 on: April 16, 2018, 06:26:54 PM »
Don't have any at the moment. The ones that are roughly the size of a loaded 38 bullet?
They fit all FE cylinder heads. I used to find them on Ford F-series trucks with 360/390 engines.
Offline lancelot66
« Reply #2 on: April 16, 2018, 06:38:07 PM »
Just did a quick search on that number and this site says that Dennis Carpenter has some in stock:
http://www.rearcounter.com/C6AZ-6052-A-parts248874.html
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
Offline outlawincorporated
  • Kangaroo Herder
« Reply #3 on: April 16, 2018, 06:59:57 PM »
Myfo28
I have a extra set of NOS exhaust plugs if needed.
regards.
PHILL BERESFORD
MELBOURNE
AUSTRALIA.
Offline Myfo28
« Reply #4 on: April 18, 2018, 01:32:16 AM »
Thanks to you all for helping me search for these cylinder plugs.  I was able to purchase a set from Mustangs Ect.
Ravens Black
R Code
Offline lancelot66
« Reply #5 on: April 18, 2018, 01:09:40 PM »
I haven't tried this variety yet, as I still have a tube of the silver stuff (which lasts forever) but you might consider using it when you do your install of these plugs:
https://www.permatex.com/products/lubricants/specialty-lubricants-anti-seize/permatex-copper-anti-seize-lubricant/
If you need to extract these little buggers for any reason later on, you'll thank yourself I think...just make sure you put it on the threads only and not over the tips. It probably would just burn off but neatness/caution counts often times.
VR/
-Lance
SJ Build Date: 1/6
« Reply #6 on: April 18, 2018, 04:30:22 PM »
I used this flavor of Permatex about 10 years ago on my "smog plugs". I guess I should pull one to see if the Permatex hype is good.
