Restoring - General discussions that span across many different groups of years and models => Misc Items => Topic started by: Anghelrestorations on June 30, 2016, 09:52:57 PM
Title: Goodyear Tire Date Coding
Post by: Anghelrestorations on June 30, 2016, 09:52:57 PM
Put together a new article on tire date coding for original Goodyear tires.  I wanted to get the usual suspects here to take a read and comment but also would like to see a few people look at their original tires to make sure this works for everyone.  Let me know if there is any questions or issues.
I did leave some information out - in particular how to decode which plant the tires were made at since in the end this isnt really information anyone really needs or wants.  Otherwise it becomes too long.
http://anghelrestorations.com/uploads/3/1/7/6/3176630/goodyear_polyglas_tires_v1.3.pdf (http://anghelrestorations.com/uploads/3/1/7/6/3176630/goodyear_polyglas_tires_v1.3.pdf)
(http://i191.photobucket.com/albums/z213/azscj/IMG_8457_zpspvqcw04t.jpg)
Title: Re: Goodyear Tire Date Coding
Post by: Smokey 15 on July 01, 2016, 08:56:01 AM
 Very informative. Thank You for posting, Marcus. I think I am going to print the article and keep a copy in our shop. I know I'll never remember all that info!
Post by: mtinkham on July 01, 2016, 01:25:45 PM
Thank you for the article....
Off topic: ....Made In U.S.A. who would have thought this would become such a meaningful and rare statement.  In the 60-70-80-90s...I took it for granted.  Now it is such a rarity and something I really enjoy seeing!
Post by: svo2scj on July 04, 2016, 12:02:16 AM
Thanks Marcus - I guess !    SCJ has a LR in the trunk - Dec 1968.   Is that ok for a APril built car??????????    ( I don't even want to look at my other ones)  LOL
Mark
Post by: Anghelrestorations on July 04, 2016, 12:18:17 AM
I cant say December 1968 is a bad thing....besides you don't have too many options to replace it.  The fact that you have a correct original tire(s) is better than most.
Post by: rockhouse66 on July 04, 2016, 08:32:56 AM
Mark - the spare in my 3/69 SJ car is dated 2/69 so it looks like the dates ran pretty tight to actual build dates.
Post by: svo2scj on July 04, 2016, 09:45:54 AM
Yeah  The "spare" is in the car as it was never removed from a rim, still has daubs on the rim and is the BEST of the 5 originals I have.   I will look at the other (maybe today).    It was hard enough getting 4 rims to match up on the dates!   Fearful I will want different original tires now !   LOL
Everyone that saw the car said "are you crazy you can't risk one of those blowing out" -it will take out a fender!    What they didn't know was that the car would be driven 1/4 mile in 6 years.  (once)
Mark
P.S.  I didn't know which hub cap to put on the car either !!   The NOS service "sticker" style or the original line STAMPED caps.  REALLY don't want to start swapping tires/wheels and caps to get right.  Then there are the original wheel weights.............
Post by: 67gtasanjose on July 04, 2016, 10:50:22 AM
...and valve stems!
Post by: svo2scj on July 04, 2016, 02:55:16 PM
...and valve stems!
That was easy - think
Mark
Post by: Dudley on July 04, 2016, 04:18:33 PM
Marcus,
I'm starting to pull out all my tires to check the dates. I have questions on the first two tires I pulled out to decipher......
1. I have a Goodyear Power Cushion 6.95 - 14 with a date code of 0N0S0B3, can a system 2 have 6 or 7 digits as a date ? I believe this code to contain zeros and not the letter O. This tire is mounted on a green painted steel rim that I was told came from an AMC car. I believe that as correct since the back side of the tire has an ink stamp stating AMC Kensha Wisc.
2. Off topic slightly  -  do you have any info on date codes for Firestone deluxe champions, specifically Z000318C ?  Thank you
Post by: Anghelrestorations on July 04, 2016, 11:18:16 PM
Dudley....yes, you can have a six or 7 digit code...the length of digits is not as important.  But to decode that tire it would be the first two digits 0N (with the first digit being a zero and not the letter O).  That would translate to November 1965.
As for the Firestone I did not do anything for the moment as they use a completely different date code system before 1971.  Thats a whole different project.
