Restoring - General discussions that span across many different groups of years and models => Drivetrain => Topic started by: ruppstang on March 23, 2019, 09:47:19 AM
I bought a 68 S code basket case project a few months ago. It is a Four speed manual transmission and the bell housing that came with it is a C5TA 7505 B.
It appears it should have a C6 OA 6394 D.
My question is will the C5 TA 7505 B work with out any modification?
Mustang Tek listed the C5 TA 7505 as a FE bell housing but not much else.
I think that is a truck bell housing and is deeper by a small amount than the correct C6 one. It can be used with a special longer pilot bearing to support the front of the trans input shaft.
I guess it's extra length is small enough it would not effect the drive shaft? I will continue to look for the correct C6 one.
the C5TA-7505-B truck bell housing is about .5 inches deeper than the car bell housing. The splines on the clutch hub will not be fully engaged on the input shaft . The shifter would also be moved the same distance further back along with the transmission.
Thanks for the information. I do not do modified Mustangs, I 'll find the correct part.
