Restoring - General discussions that span across many different groups of years and models => Body, Paint & Sealers => Topic started by: T Lea on January 08, 2011, 08:56:34 AM
Anybody have a mixing, MSDS sheet for Delstar DAR? PPGs website is not user friendly. I also need one for PPG flattener
i found this link...does it help??
https://buyat.ppg.com/refinishProductCatalog/SearchMSDS.aspx?&Keyword=dar
I have learned that when searching for paint product MSDS's and Product Data Sheets for jobs we are doing at work, I don't get trapped in a revolving door by going to the MFG website. Instead, I Google a string something like this:
SEARCH BOX ENTRY PPG delstar MSDS PDF or PPG Deltar flatener PDF
In my experience, this will get right whereyou need to be. These documents are usually in PDF format and by putting that in the search string, it filters out all the riff-raff.
I got these on the 1st, 2nd and 3rd searches.
http://www.tcpglobal.com/docs/ppgdarp.pdf
http://hazard.com/msds/f2/bkd/bkdhl.html
http://www.myrv10.com/N104CD/paint/p-162.pdf
http://www.romeolima.com/RV3works/Paint/P-162_DX685_Flattening_Agent.pdf
http://www.ppg.com/coatings/refinish/en/safetyhealth/Pages/010_msdsSearch.aspx
Tim,
What are you going to use the PPG DAR with flattener for? Engine paint? I did that on the yellow coupe. Came out ok...seems a little thick compared to the original Ford engine paints. Also, I have all of the MSDS sheets for the DAR products.
Regards,
Pete Morgan
Yes. I've used it in the past with great results but lost my mixing sheets. I printed them from the links above, thanks to all.
