Restoring - General discussions that span across many different groups of years and models => Body, Paint & Sealers => Topic started by: 1of111 on May 06, 2013, 07:23:41 PM
Hi all
Can anyone tell me the codes for Wimbledon White & red for interior .
Thanks & regards
Eric.
Hi all
Thanks & regards
Eric.
Eric - what year are you working on??? Spring 68 and built @ San Jose?
Can't help without some info ;)
J-Speegle
Thanks for your quickreply
I'm working on an early 64& 1/2 VIN . 5F07D....... , door tag 65A M 85 31C 91 1 5
Thanks again
Wimbledon White - Ditzler 8378 (a number of years list more than one number for the same color)
Interior Red - Ditzler 71315
With that said these old paint numbers may be of little use today with the reformulation (may times over the years) of the paint products available today. What is available for sale and use (often two different things) also can play a part in availability.
Hi again ,
how about the color of the undercarrage I was told either Slop Grey or black which one of the two and if its the grey is there a code for that too.
Regards
Hi again ,
Regards
Allot of the blacks turn out to be a dark slop. Color and tint can vary allot but there will be no code for you to use. Will look to see what I've got around your time period for you to aim for.
Looking through my pictures I've got nothing from that plant that time period with good clear shots of the undercarriage color. Hopefully someone else will have an example
That would be very much appretiated and thanks for your help
Regards
Eric
