Author Topic: Correct threaded studs corral horse?  (Read 915 times)
Offline Ralf
« on: May 31, 2017, 09:59:09 AM »
Bought a NOS corral horse. Unfortunately when part arrived, one of the threaded studs was bended. No way to re-bend.
Does anybody know the some details?
Need to buy a new one.
- thread pitch?
- fine thread?
- inch? SAE #10? >> 4,8mm outer diameter?
Thx
Ralf
Re: Correct threaded studs corral horse?
« Reply #1 on: May 31, 2017, 12:45:34 PM »
It should be a 10-24X2.0 inch long stud with lead point tip ends. Your picture shows a slight lead point tip on your NOS Corral. I measured the studs from a 67 Corral at least 10 years ago but I am not sure about the lengths, it may be 1 1/8 inch long. The stud does not have known Ford part number. AMK does not carry it, but AMK does have two that "may" work, AMK B-12600 (1.0 inch - too short) or AMK B-12601 (1 7/8 inch, can be cut but wrong finish and lacks lead point).
Offline Ralf
« Reply #2 on: May 31, 2017, 12:59:00 PM »
Thx for your answer.
May be someone has such an original  stud for sale?
I'm looking for the one on the bottom side (middle)
Original length is around 2 inches ( 4,8cm).
Looks close:
10-24 X 2.0 FT STUD, ZC. 6 pk    8    B-12601    $3.00
« Last Edit: May 31, 2017, 01:10:25 PM by Ralf »
« Reply #3 on: May 31, 2017, 01:27:40 PM »
Very easy to take a longer one and cut it down, add the lead point.(clasp the threaded rod in a power drill & file/grind it down as needed). These bolts are not in any "easy to see location" but I suppose a person could get it zinc plated also, within another order if they wanted the correct finish.
Offline Ralf
« Reply #4 on: May 31, 2017, 02:09:44 PM »
Smb can post a picture showing original lead point tip end?
