Marketplace => Parts for Sale => Topic started by: Fordman265 on April 22, 2018, 10:58:41 PM
Autolite 4100 Carburetor is very clean and in great shape, but will need a rebuild kit (needle valves are missing)
Body numbers: C5ZF D
Casting number on bottom: 7-27-64
1.08 venturi Primary jets: 46F Secondary jets: 57
Automatic choke and dashpot
More pictures available or I will take what you want to see
Archie
(303)901-3282
abaj1@msn.com
Top tag: C5ZF H (H has been scratched out and D hand scribed. Not sure this tag is original to this carb)
A C5ZF-H carburetor is a 2100. It should be C5ZF-D. You're correct, the tag is not original.
The casting number, 7-27-64, is on a lot of 4100 in the 65 time period. The tag would have the carburetor's assembly date.
- but will need a rebuild kit (needle valves are missing)
The originals were steel, replacements are brass. They work fine, just not concourse correct.
Thanks for the information Jim! I will remove the tag from the carb.
For that kind of money, your C5ZF-D carburetor should have the correct primary and secondary boosters. Many have been rebuilt over the years and have the incorrect boosters. The primary booster should be stamped "CH" and the secondary booster should be stamped "A". You have to take the boosters out to check the stampings. I would not pay that kind of money without confirmation. It would cost another couple of hundred dollars to restore. That carb is worth $250 at best if everything checks out.
I will check the boosters this weekend and post pictures of what I find.
Here are the pictures of the two boosters. First is primary and second is the secondary.
Carb is no longer for sale.
Thanks for the information. Where can I learn which boosters belong in which 4100 carb?
Topic split rather than continue in the For Sale section
It can be for here ;)
http://www.concoursmustang.com/forum/index.php?topic=18110.msg114611#new (http://www.concoursmustang.com/forum/index.php?topic=18110.msg114611#new)
