Restoring - General discussions that span across many different groups of years and models => Processes, Products & Techniques => Topic started by: slk25 on February 08, 2024, 05:01:50 PM
I started to remove my leaking front windshield and had the presence of mind to look around for additional tubes of 3m 8509 Bedding and Glazing compound, since I only have one six year old tube on hand.
No parts store in my area has any of the 3M material, and when you look on the 3M website it says it is obsolete.
The local Napa guy says CR Laurence CRL7708 is equal, but reading the reviews online it appears to never dry out.
Has anyone on this forum use the 7708 material and what did you experience for difficulty installing the glass?
Where do you live? NAPA shows it in stock.
https://www.napaonline.com/en/p/MMM08509 (https://www.napaonline.com/en/p/MMM08509)
that link shows out of stock for me.
My link to my local stores shows for store pick up order today and pick up tomorrow for all of them as if it is available. However it says "We apologize this item is not available for shipping at this time. However, this item may be purchased at a NAPA store. If the item is not in stock at your local store, then your store associates can order the item for you. We apologize for the inconvenience. Thank you for shopping at NAPA "- That is as of today in KC.
Windo-weld 8609 was good stuff. I used it for gluing down the windshield trim on my wife's ASC.
Napa picture is different from the product description/number MMM 08509 Bedding & Glazing.
The NAPA picture shows exactly what I have been using for decades. It's hazmat so there is no shipping - you have to pick it up in your local NAPA store.
The only alternative available is this liquid butyl stuff. It's sticky/messy like the newer 3M strip caulk:
C.R. Laurence CRL7708 CRL Windshield and Body Sealant
Thanks for the heads up, I found the last tube in Omaha and the last one in Lincoln.
does this have an expiration date??
Depends how it's stored. I've had tubes for years and seemed fine.
My son found two more in a small town near here. Now we have enough for all of the cars we have in the que.
If you need some, I would start making some calls.
What I recommend is calling your local stores as Mr. Gaines recommended.
It is out of production, but I was able to find 4 tubes that way. It was on the top shelf in the back storeroom and they had to look for it. It helped I had pics of what the container looks like.
That worked for me, and I am sure there are lots of stores with old stock sitting on back shelves.
As for it going bad? I assume that if you have a sealed tube or partial used tube that is capped and inside, it should theoretically last a LONG time. Since it stays pliable and is subject to extreme weather after used, I would think it would not go bad stored inside on a shelf. Just my opinion though.
My only question is how many tubes does it take to do one car?
Dan in Kansas
Dan, i was also wondering how many tubes as i start hunting around In this blog, i saw mention of 3 tubes to do a 65 windshield. Might extrapolate from there.
http://blog.virginiaclassicmustang.com/2013/02/65-68-mustang-windshield.html
A windshield can be done with 1 tube, maybe another half a tube at most. 3 tubes is enough for 1 car, front/rear windshield. I also used it for door/qtr water shields.
Charles, thanks! looks like I need to hunt for two more to ensure I get both done cars one of these years.
AJ,
thanks for the BLOG I see it mentioned, now if I can only get the BLOG pics to open up.
Maybe my Gov't computer rules is blocking, I'll try at home later.
Dan
AJ,
Pics really helped me understand thanks for the blog link.
I wonder if three tunes are required for 70 mustang or less than that?
A week after my initial Napa order I get a phone call with a conflicting double talk explanation why it is not here yet with the end result being they can not get anymore and it is obsolete.
Thank you Bob for following up.
I have run into the same situation in Ohio.
Looks like I will be ordering the C.R. Laurence CRL7708 CRL Windshield and Body Sealant.
I feel pretty lucky to have found four tubes. I tip that I use when installing glass is to lay a strip of 3M strip calk in the glass grove of the gasket then install the gasket on the glass. Afterward I seat the gasket by taping it with a rubber mallet. This method is less messy and will make the 8509 go further.
I did not even get a phone call. I just got an email that said my order was cancelled due to the item not being available. I guess it will be strip caulk in the future for me.
I found out today that there is another brand available. It is CRL windshield and body sealant. Walmart has it for $14.
I found out today that there is another brand available. It is CNL windshield and body sealant.
Is there a part number?
https://www.crlaurence.com/All-Products/Automotive-Windows-%26-Supplies/Automotive-Glass-Supplies/Glazing-Adhesives/Epoxies%2C-Sealers%2C-Urethanes%2C-%26-Adhesives/CRL-Black-Windshield-and-Body-Sealant/p/CRL7708
Team,
I saw the CRL advertised as well. It appears to be same product just not sure. I found six tubes total of the 3M 08509 by calling every auto parts store in my surrounding county. They were all old stock on back shelves. Anywhere from $18-24 a tube. I recommend checking window installer places as well. They sometimes sell stuff like that if you tell them your dilemma. Hopefully someone will report how the CCRL compares. I'm too far away from time to use any to be of help.
Dan in kansas
I ordered three tubes of the CRL7708 on Amazon. I will not use it until maybe May or June but it looks like the same stuff as the unavailable 3M product.
The CRL stuff looks like the tube version of 3M strip caulk... the sticky butyl type.
I ordered a few tubes a while back but haven't used any.
