Restoring - General discussions that span across many different groups of years and models > Parts
Coil Bracket
Brian Conway:
Looking for some help with indentifying this coil bracket. Seems to be for a BB intake manifold application ? The hole in the strap and the added reinforcing metal at the bolt hole area seem to qualify it for a particular application ? Any help or suggestions. Thanks, Brian
Bob Gaines:
--- Quote from: Brian Conway on July 13, 2015, 11:29:36 PM --- Looking for some help with indentifying this coil bracket. Seems to be for a BB intake manifold application ? The hole in the strap and the added reinforcing metal at the bolt hole area seem to qualify it for a particular application ? Any help or suggestions. Thanks, Brian
--- End quote ---
The hole is a locating aid to index the coil. The coil would have a bump to fit in the hole. This was phased out in 1965 production . I have heard that coil bracket stock was used up after the transition but have never seen a example that I could rely on myself. I would think that the odds of it being appropriate on a Mustang given the time frame used and the BB application would be somewhat remote. A anomaly at best on a Mustang given the BB strap. More likely a 64/65 full size car application IMO.
GD64:
These are images from a '63 FE and what is on my '64 390 (mounted to the DS head. (non air)
I haven't been able to find any information within the 1960-64 Ford car parts & accessories catalog (dated 1969 :'() in respect the possibility of a design change for the compressor mounted coil strap.
Brian Conway:
Thank you guys for the replies. GD I have never seen a bracket quite like your example. Bob your info helps to narrow the field. So pre-65 and full size FORD car line. Big help. Brian
GD64:
G'day Brian,
That coil and strap that i have shown is from a 63 Galaxie, which is identical to '64.
[#] Next page
