Author Topic: Yellow (gold) plated carburetor parts.  (Read 1901 times)
Offline 66candy
    • 66 Mustang Convertible Phote Book Restoration
« on: May 28, 2010, 08:14:59 AM »
Lately I see beautiful "concours" restored 2100 and 4100 Autolites with lots of yellow or gold plated parts. Almost every part which is not made of alumium is plated in that color: choke and throttle plates, linkages and even the air cleaner stud. Is this concours correct or just for the looks?
Here's an example:
Erwin, The Netherlands
66 Red Convertible, 289/4V AT/PS/PDB/PT
Re: Yellow (gold) plated carburetor parts.
« Reply #1 on: May 28, 2010, 09:19:57 AM »
It is mostly correct.
Offline ajd350
« Reply #2 on: May 28, 2010, 11:02:32 PM »
Can you elaborate, Charles? As far as I know, the Idle speed screw/spring and the carb stud should not be in that finish.
MCA #2254
« Reply #3 on: May 29, 2010, 01:36:17 AM »
Idle screw and spring are typically zinc dichromate.
Otherwise, couple minor observations:
-Primary throttle shaft return spring is typically light blue color, almost like silver blue.
-Accelerator pump cover and secondary pump cover should be more of a natural color (not the holley style)
-Hard to tell in the pics, but the butterfly shaft should be brass
