1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year > 1966 Mustang
clarification on sheet metal stamp dates
rocket289k:
Since it's a NJ built (Metuchen) car if you had the Buck Tag - you'd know the date the body was bucked (aka unibody started to be welded together).
Regards,
Ron
evantugby:
Buck Tag shows
C/O 670
13 L4 6T09K134680
63A Z 26
4 SPEED HP PIO
I know what PIO means thanks to Jeff.
CharlesTurner:
c/o is thought to mean 'customer order', but I don't believe the Ford assembly plant would care one way or the other enough to mark a bucktag with information like that. The intent of the bucktag was to ID the car and options, but also to ID options that required some type of modification to the basic unibody.
13 is the welding bay
L4 is the date the car was bucked, November 4th
4 SPEED was on the buck tag since an additional hole was needed on the toe panel riser for the speedometer clip
HP for the choke cable hole in the firewall
PIO for the GT options, which included different dual exhaust reinforcements in the rear, plus holes in the rad support for fog light wiring. Maybe also includes the hole for the proportioning valve mount.
CharlesTurner:
Concerning 'c/o'. The other codes there would be 'D'. So, some say 'customer order' or 'dealer order'. Pretty much all cars would be ordered by a dealer, so it doesn't really make any sense. I've correlated original order sheets with buck tags and they don't always match up with 'Retail' or 'Stock' order type. It could have something to do with deviations from the basic unibody. Kevin Marti notes in his Tagbook that the codes were internal, but doesn't state what they mean.
[*] Previous page
