Author Topic: 1967-68 Safety Convenience System - Application, Components, Wiring, Lenses and Bulbs  (Read 42342 times)
Offline 196667Bob
Interesting topic!
Jan. 67 Dearborn
From solenoid follows harness along front of radiator, up drivers side to about 3 inches from firewall. Then over booster through clip on firewall just for it. Ends in 3 position receptacle, about 4 inch wire with plug then goes through firewall hole with goop around it. Firewall hole about mid way between shock tower braces.
Upper Left - DOOR
Lower left - BELT
Upper Right - FUEL
Lower Right - PARK  (Flashes)
If the engine is being cranked for awhile the FUEL light will flash.
Jim : Thanks for your Reply. A couple of questions :
1) What day of January 1967 ?
2) Since you added information about the lenses ;
     a)  Is it "BELT" or "BELTS  ?
     b)  Color of lenses (Red or Blue) ?
     c)  Are lenses "backlit" or is printing in white on face of lenses ?
Thanks again for your help.
Bob
MCA 04909
Offline 196667Bob
Keith :On your Reply #   143, didn't you mean "Nov 1966  ?
Belt, Door, Fuel and Brake. Left to right.
Since you added the above information on the lenses, a couple of questions :
b)  Color of Lenses ?
Thanks again,
Bob
MCA 04909
Offline 196667Bob
Bob, I was at NPD in January and the vehicle is no longer on display. I will call and ask Wade if he can provide the VIN for our little study.
        -Keith
Keith : Thanks for your offer to contact Wade. When you do, the VIN number isn't necessary, just the "Build Date" and whether the "Proof Wire" heads toward the Firewall on the Passenger's side or the Driver's side.
Bob
MCA 04909
Offline 67gta
Bob
Jan 6th.
Black circle (no backlit) purple/blue DOOR letters
Red circle (backlit) white BELT letters (no S)
Green circle (backlit) white FUEL letters
Black circle (no backlit) red PARK letters
Bob
Scheduled 12/16/66 actual 12/19/66
Offline 196667Bob
John : Thanks. Being that it is a 1966 Build Date, based on the known 1966 Builds we have documented, it probably has the Proof Wire along the Driver's side, but would be nice to know for sure.
Bob
MCA 04909
Don't know if this will help but here is a picture of the dash panel from 8F03S1232xx. Sorry don't have a real build date. Will keep an eye out for more
Offline 196667Bob
Jeff : Thanks. We don't have a lot of pictures of 68's with the SCS, so yes, this helps.
Bob
MCA 04909
Bob
A few more pics, including back side found on an eBay sale:
Offline 196667Bob
Jeff : Thanks once again for posting some pictures. It's good to have some more 1968 info.
A word of caution though for those viewing these. The bezels and lenses shown with the Dash Panel appear to both be the Scott Drake reproductions. I say this based on two observations. First, the use of "SEAT" for the Seat Belt Warning Light only has been shown to appear on the reproductions. In the research and documentation done so far on 1967 and 1968 Mustangs with the Safety Convenience Option, the majority have "BELTS", and two have been noted as "BELT", singular. And secondly, the steel "tubes" to which the bezels/ lenses shown in your pictures are attached (the reproduction bezels/ lenses do not come with these "tubes") are not correct for the Mustangs or the non-padded console Cougars. The correct tubes have the "prongs" that hold the assembly in the dash panel or console, located right next to the "mushroomed" end of the tube (see first picture attached). The "tubes" shown that are attached to the bezels clearly show that the "prongs" are not at the end of the tube. These tubes were used on the Early Cougars with the padded consoles and on most 1964-67 Thunderbirds (see second picture attached). These "tubes" can only be used successfully on the Mustangs with the addition of a 3/16" spacer.
Thanks again,
Bob
MCA 04909
Thanks again,
Bob
I wonder what 68 Mustangs WITH Air Conditioning have. They have a padded console surface and radio face panel. Likely the 2nd version shown in your pictures
Here are some more details on the routing of the proof wire C7ZB-9C877-A.
Also from this thread: http://www.concoursmustang.com/forum/index.php?topic=14006.msg128726#msg128726
There is a question about proof wire taping and clamps for support purposes.  I found no evidence of these in the attached document.  Perhaps this explains why some of the wire is missing!
« Last Edit: May 27, 2019, 08:38:52 PM by 67gta289 »
This is a very interesting thread. One thing I did not see over the previous 11 pages was the electrical schematic from Ford. Here is the '68 schematic.
Here is the 1968 Convenience panel General Arrangement for the wiring and components.
This schematic is also found in the electrical book:
