Author Topic: 65 Tag Light  (Read 1386 times)
Offline Brian Conway
65 Tag Light
« on: October 29, 2014, 06:27:38 PM »
     Discovered a date stamp on my tag light and wanted to share some Mustang trivia.  Little tough to read but stamped 5E.  Are the mounting screws correct or should they be hex heads ?Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline Richard P.
Re: 65 Tag Light
« Reply #1 on: October 29, 2014, 06:32:45 PM »
The mounting screws I' are correct
Offline Richard P.
Re: 65 Tag Light
« Reply #2 on: October 29, 2014, 06:33:46 PM »
The mounting screws I've seen are as you show. They were not painted.
Re: 65 Tag Light
« Reply #3 on: October 30, 2014, 12:58:24 AM »
The two mounting screws are: 52727-S39 (cad) for 64, -S40 (clear zinc) for 65, and -S36 (gold zinc) for 66, 10-12X1/2Pan head. The light housing is gold zinc plated as individual parts and riveted together with 2 aluminum rivets. The glass retainer screw is also gold zinc.
I've seen date codes missing, with one letter, written "number first" and written "number second". I don't know which plant they came from.
Online CharlesTurner
Re: 65 Tag Light
« Reply #4 on: October 30, 2014, 10:29:58 AM »
The 2 semi-tubular rivets holding the pieces together are normally steel with zinc plating.
Re: 65 Tag Light
« Reply #5 on: October 30, 2014, 07:26:05 PM »
After I drilled out the rivets I checked the material with the old magnet test, they were not attracted, eg - aluminum. That was a couple of years back. Still, I checked a couple more housings in the TBD stack, five to be exact, and on four the magnet stuck, one would not hold the magnet, aluminum. Sources are unknown. The date code on the odd one is F6, June 1966, last of the 66 year. I believe that the steel rivet is more appropriate as aluminum and steel do not get along in a wet environment.
