1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year > 1967 Mustang
67 Running Changes Main Thread - San Jose Findings
(1/1)
J_Speegle:
8/26/2020 NOTE: Screwed up and deleted old thread by mistake. Not sure if Charles can go back and rescue an old copy but that may take some time so in the meantime will try and recall all the subjects we have covered and those mentioned. Invite anyone that recalls some of the many ones we had (just the subject will help. Will add them to the list and delete (carefully this time  ::) the suggestion when added
Didn't have anything else to focus my time on I guess :( but its just what it is
So here is another Running Changes thread this time focused on 67 San Jose Mustangs. We'll follow the same post, discuss  (if need be if it belongs), add to the list, then delete the suggestion to keep the thread compact and up to date as much as possible.  So post what you understand was affected by running changes and I'll keep an ongoing list here in the first post. Some of these will likely match other plants fairly close and some items will list the dates from the TSB and other supporting documents also as we have elsewhere.  From there we'll collect data, assemble the first report and see how it works.
To keep the thread from getting too long or out of hand please don't post that you found this version or that on car 7F02C2345xx (for example). We can save that for the research period and for the individual change threads. Just trying to identify the features during this first effort. Will break out the findings by plant of course.  Hope we can work through other plants also
Drivetrain
Engine
E1- 289 Exhaust manifold to engine hardware -
       http://www.concoursmustang.com/forum/index.php?topic=23163.0
E2- 390 Valve cover design differences -
E3- 289 Valve spring issue - Might be better described as a fix or problem on engines between Dec 9 1966 and Jan 23 1967
E4- 289 Distributor housing - Change from FoMoCo cast to AUTOLITE casting logos
E5-
E6-
Transmission
TR1- 289 K code manual transmission - Change from RUG-BX to RUG-N1 version
TR2-
TR3-
TR4-
Rearend
R1- 8" Oil fill location Transition third members without a fill plug to ones with a fill plug. Since this is not solely a San Jose details we will also
       link the other two plant running change threads once established.
      https://www.concoursmustang.com/forum/index.php?topic=27469.new#new
R2- 9" Oil fill location
       Transition third members without a fill plug to ones with a fill plug. Going to use this to solely focus on the date change
       at the casting plant and the thread below for the location and comparison for both fill locations. Since this is not solely a San Jose details we will
       also link the other two plant running change threads once established.
       https://www.concoursmustang.com/forum/index.php?topic=27468.new#new
       Transition from in the rearend housing (facing rearward) to being located in the removable third member
        http://www.concoursmustang.com/forum/index.php?topic=20939.msg131731#msg131731
R3-
R4-
R5-
Engine Compartment
EC1- Radiator support attachment hole - Change from oval to a square with notch style hole. Survey returned a change over range between March 2 and 8-9 1967
       http://www.concoursmustang.com/forum/index.php?topic=21871.0
EC2- Windshield washer reservoir - Change from soft plastic washer bag to hard opaque "bottle design. Survey produced a change over date between March 29th and April 7th 1967
       http://www.concoursmustang.com/forum/index.php?topic=20718.0
EC3- Additional battery hold-down bracket - Use/installation of a small L shaped bracket between the outboard battery hold down bolt and the inner fender panel
       http://www.concoursmustang.com/forum/index.php?topic=20719.msg130479#msg130479
EC4- 390 Thermactor system filter location -
EC5- Hood turn indicator bezel/insert changes - Addition of sealant between grill land body. Changed/added during November 1967 all plants according to TBS #1217
EC6- Engine vacuum reservoir style and location -
EC7- Brake line routing at steering column area - Survey indicates that the change took place at San Jose between April 26/28th and May 1st 1967
        http://www.concoursmustang.com/forum/index.php?topic=20967.0
EC8- Service specification decal - Current change from 66 style to the 67 style, according to examples so far, was from November to mid January
       http://www.concoursmustang.com/forum/index.php?topic=20849.0
EC9- Horn date code markings - Change took place where the style of marking the date on horns changed from a white ink stamp to having the date stamped into the metal horn housing.
Exterior
EX1- Hood substructure differences - Versions with round holes verses those without this feature
       http://www.concoursmustang.com/forum/index.php?topic=5026.60
EX2- Rear valance screws - Since the screws were installed at different station on the line the study looks into the style of the screws that were originally used to determine, if possible, any patterns
       http://www.concoursmustang.com/forum/index.php?topic=21331.0
EX3- Door hinge style change -
       http://www.concoursmustang.com/forum/index.php?topic=20911.0 and http://www.concoursmustang.com/forum/index.php?topic=18300.0
EX4- Cowl Panel Access Holes - Earlier cars had round access holes on the outer ends of the cowl panel but these were eliminated in later production. Change period currently narrowed
       down to possibly the first of March 1967 approximately
       http://www.concoursmustang.com/forum/index.php?topic=23705.new#new
EX5- Rear door glass seal/gasket - Change of shape/design of this rear rubber seal at the rear door opening to rear edge of the door glass stainless. MPC lists that the change took place
       on 12/15/66
EX6-Roof rail weather strip for coupe body style -  1969 MPC list a change took place 9/22/67 when the part & number was changed C7ZZ-6551222-A & C7ZZ-6551223-A to
       C7ZZ-6551222-B & C7ZZ-6551223-B No details of the change are available as of yet.
EX7- Rear Valance - Discussion started here from a couple of posts originally posted to this thread
       https://www.concoursmustang.com/forum/index.php?topic=26369.msg162469#msg162469
EX8- Windshield washer nozzles - Change from single orifice with cad or zinc plating to dual orifice nozzle plated in a dark bronze coloring.
EX9- Vinyl Top - Coupe - Change from no "fold over" seam on the A pillars to the design with a seam on each at the top of the pillar
EX10-
EX11-
EX12-
Interior
I1- Bucket seat track plate design change -  Separate plate design to plates attached to the stud track section
       http://www.concoursmustang.com/forum/index.php?topic=22836.0
I2- Deluxe bucket seat trim attachment - Change from a version using four screws for attachment to an "improved" five screw version.
I3- Fastback rear quarter panel covers and latch cover plate - Change from early version without trim plate at fold down latch
       http://www.concoursmustang.com/forum/index.php?topic=13555.0
I4- Fastback trap door upper trim - Change from the earlier version where the trim strip was attached using threaded studs to a version where three visible, from the interior, held the strip to the trap door.
I5- Driver's side air vent - Change from metal to plastic design. Current information suggests the change took place between October 14th-29th
       https://www.concoursmustang.com/forum/index.php?topic=28015.msg171140#msg171140
I6- Interior seat insert material changes - Though we understand that the change between the smooth and comfort weave inserts was due to a supply issue it would still be good to document when the changes took place at San Jose for this thread
I7- Interior choke knob design - On K code optioned cars a change from the 66 style choke knob with the white "C" in the center of the knob to a version with no "C"
I8- Deluxe interior door panel inserts - Change from the brushed aluminum from a beaded forward edge that followed the edge to a later non-beaded froward edge that curled around the upper corner edge of the door panel
I9- Interior day and night mirror -
       http://www.concoursmustang.com/forum/index.php?topic=20800.0
I10-
Trunk
T1- Driver's side trunk filler board - Change from masonite/fiber board to cardboard style. 2016 findings - December to  first week of Jan is holding true so far
        http://www.concoursmustang.com/forum/index.php?topic=14388.msg89539#msg89539
T2- Fastback Only - Trap door arm hook - Change from slotted hook to single arm style
       https://www.concoursmustang.com/forum/index.php?topic=26066.new#new
T3-
T4-
Undercarriage
U1- Fuel line routing - Inner (down the driveline tunnel) verses outer (routing along the drivers side rocker panel) Change over appears to have taken place between 3/16/67 and 3/22/67
       http://www.concoursmustang.com/forum/index.php?topic=22685.0
U2- Main floor pan/panel reinforcement design change -
       http://www.concoursmustang.com/forum/index.php?topic=18111.0
U3- Disc brake caliper design changes - Not a specific thread on  San Jose or a survey but does describe the differences and some possibilities of the change over period
U4- Battery tray reinforcement - Spot welded to bottom side of the forward passenger side inner fender panel there was change from a narrow and a wide version of this reinforcement plate
U5-
U6-
Last Updated - 2/27/2023
67gta289:
Here is the 1968 MPC based 1967 model year running change document that I worked up.
67gtasanjose:
C8 302 block with 289 internals
Also, was there ever an early battery heat shield (the kind that has a hole for the posts) ever used in production?
J_Speegle:
--- Quote from: 67gtasanjose on March 22, 2023, 08:40:13 PM ---C8 302 block with 289 internals
--- End quote ---
Any idea or data points to help suggest when those went into production and at which engine plant?
--- Quote from: 67gtasanjose on March 22, 2023, 08:40:13 PM ---Also, was there ever an early battery heat shield (the kind that has a hole for the posts) ever used in production?
--- End quote ---
Yes and no based on pictures. I know of no documentation that they were ever used/installed at one of the three plants that built Mustangs. Only example I have is from a Fairlane from a road test and those were typically production vehicles not prototypes like ones used sometimes in advertising
67gtasanjose:
--- Quote from: J_Speegle on March 22, 2023, 11:05:10 PM ---
--- End quote ---
Bob Mannel's Small Block book, page 7-4, paragraph 7A2, states the C8OE-6016-A began being used at the Cleveland plant as early as May, 1967.
On a seperate note, I found information in the 67 Ford Mustang Shop Service Manual as well as Mannel's book, that change level L15, 289 Thermactor 289's with auto trans., have higher lift camshaft specs. I'll try and find more reference information and update my findings. (Mannel's page 7-7, paragraph 7B4)
I have no other data to offer at this time excepting internet clammer.
