Restoring - General discussions that span across many different groups of years and models > Drivetrain
C8 AE-A water pump
TLea:
If NJ plant I've only ever observed -J on original cars
J_Speegle:
Should not be a difference between plants since the water pump was installed at the engine plant not the car plant ;)
67gtasanjose:
Is it a possibility that the -A pump was initially used on the late-67 produced 289 engines (the ones using the 302 blocks)?
These late-67 289 engines used different timing covers, different thermostat housings, different lots of items on the front of the blocks.
TLea:
--- Quote from: J_Speegle on February 20, 2024, 02:40:58 PM ---Should not be a difference between plants since the water pump was installed at the engine plant not the car plant ;)
--- End quote ---
Agreed. Just wanted to keep full disclosure
[*] Previous page
