1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: ruger on June 04, 2018, 02:25:52 PM
While I had the axle removed to change out the differential, gasket 8" I took advantage of the opportunity to clean and paint the axle and differential. While cleaning the differential I did not find any red oxide anywhere on the axle. Black on the tube housing with some yellow markings but no red oxide. Any thoughts about what color I should paint the differential?
The axle housing is typically semi gloss black. The pumpkin was red oxide. If that was not red oxide, I would suggest it was rebuilt at some time.
Thanks, after taking the differential out of the garage and into the sunlight I can see the red oxide now. I am repainting it red oxide now. Was questioning it yesterday.
If you want to be an overachiever, there were bare metal machine marks on the pumpkin, after it was painted.
Thanks, I will look into that.
