1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1966 Mustang => Topic started by: socalgt on July 09, 2015, 08:01:26 PM
Title: '66 dual exhaust(intermediate)hanger finish
Post by: socalgt on July 09, 2015, 08:01:26 PM
What was the original finish on the dual exhaust hangers that attach to the studs exiting the rear floor area...they attach directly to the mufflers...I see them available in silver zinc and black.
Title: Re: '66 dual exhaust(intermediate)hanger finish
Post by: jwc66k on July 09, 2015, 08:18:11 PM
They were natural. I lightly phosphate and oil the ones I reuse. The factory stud plate, C1VV-5B236-C uses lead point (aka dog point) 3/8x2.0 studs. There are a couple of reproductions that use 5/16-8 standard tip studs. Avoid them. I don't know if the stud plate under the seat on the inside is coated or not. It may get a shot of sealer after installation. The studs thru the body are sealed with calk (strip calk will work).
The retaining screw, 51866-S8 (52735-S8 what I found in mine) and the nuts, 373403-S8, or 374380-S8, or 376424-S7 to the bracket are clear zinc plated.
Post by: J_Speegle on July 09, 2015, 08:42:55 PM
+1
Plate is/was bare steel (don't really see it) Then the studs are a darkened finish - I just gun blue them and oil the assembly
Post by: socalgt on July 09, 2015, 09:11:41 PM
Thanks for the detailed replies.....
Post by: CharlesTurner on July 10, 2015, 12:46:40 AM
Stripping, bead blasting and tumbling give nice results if originals are not heavily pitted.  Scott Fuller is making some really nice reproductions now, in the original appearance.
Post by: Scott Fuller on July 12, 2015, 03:15:54 PM
I have the retainers finished with the correct plate and weld stud & point.
I should have new reproductions of the muffler hangers done later this summer or early fall.
Scott
Post by: dcenicco on November 21, 2017, 04:39:52 PM
What are your thoughts on how to strip, bead blast, etc.  considering the rubber tire in the middle? Thanks
Post by: J_Speegle on November 21, 2017, 06:43:54 PM
I think your going to find (just based on appearance) that the metal is going to be very pitted and possibly eaten-ed away in areas on your examples. Take and see if you can chip away the edge on that inner bracket and if it chips off and the brackets themselves show heavy pitting I would look towards replacing them  as no cleaning or process is going to make them usable IMHO. If they can be saved your going to be looking at grime and oil cleaning, evapo rust soak, tumbling of the metal, trimming of the rubber edge and then hope they still look like what they did before all that
