Restoring - General discussions that span across many different groups of years and models => Suspension => Topic started by: evantugby on February 18, 2018, 10:40:06 PM
Title: leaf spring clamp installation
Post by: evantugby on February 18, 2018, 10:40:06 PM
Is there a specific tool to put these leaf spring clamps on? How are you guys doing it?
Second question: do you put them on before leaf springs are mounted to kar?  they're in installed?
Title: Re: leaf spring clamp installation
Post by: J_Speegle on February 18, 2018, 11:09:19 PM
When in doubt copy what the factory did   ;) They were installed to the springs before they were shipped to the car assembly plants
Series of C clamps. Believe someone posted a series of pictures of the arrangement in a prior thread
Remember to protect surfaces from scratching the spring or clamp finishes.
1- Springs bolted together- held secure to a bench or some form of holder.
2- One C clamp to hold the clamp in place to the spring. If you center it or slightly off center towards the side with the hole in the strap
3- One C clamp to hold the sides into the spring.
4-  Collapse/bend the end of the strap with the tab to the spring surface. If you off set the first C clamp then you can close it completely.
5- Remove the first c clamp if you haven't already and close the other end of the strap and engage the tab tightly
You done - remove everything and move on to the next one. Don't forget the insulator
Post by: CharlesTurner on February 18, 2018, 11:24:11 PM
I use a bench vise with smooth jaws and a hammer.
Post by: evantugby on February 18, 2018, 11:29:24 PM
Thanks Jeff!  I'll knock this out tomorrow.  It's a federal holiday so a down day.  :)  BTW, when you say clamp insulator, you're referring to the rubber insulator already attached to each spring clamp in the picture, correct?  If so mine came attached.
Post by: J_Speegle on February 18, 2018, 11:34:01 PM
..................... BTW, when you say clamp insulator, you're referring to the rubber insulator already attached to each spring clamp in the picture, correct?  If so mine came attached.
Yes one in the same. Forget it or it falls off your not going to be happy
Post by: evantugby on February 19, 2018, 10:02:06 AM
Copy that!  Thank you.
Post by: 67gtasanjose on February 19, 2018, 10:07:32 AM
NOTE:
I have seen a dimple on the sides of original straps, not found on the reproductions that I have bought. Perhaps this had to do with how they were "pinched/bent" around the springs?
Post by: J_Speegle on February 19, 2018, 06:12:38 PM
NOTE:
Not sure if that detail was there on all years and both styles of clamps.  Do your clamps have the round or square tab hole?
Post by: 67gtasanjose on February 19, 2018, 06:31:28 PM
Square tab hole. These are off a Sept '66 dated pair of springs I had sent in from So. Calif.
Post by: J_Speegle on February 19, 2018, 09:43:23 PM
Need to look through a bunch of pictures for additional documentation, details and examples
Post by: evantugby on March 17, 2018, 11:58:21 AM
I am hoping to install my leaf spring clamps today.  I am trying to find the correct positioning and also if my 1966 Metuchen kar had round or square tab holes.  My springs are:  C4ZA5556S with build dates of 295E5
Thank you!
Post by: Bossbill on March 17, 2018, 01:46:45 PM
Is this a good thread to discuss the change over date from square to round tab hole?
On edit -- see my reply 14 below.
Post by: evantugby on March 17, 2018, 02:32:15 PM
Found some concours pictures online showing the correct location for leaf spring clamps.  Wanted to provide a few pictures for those who want to know how to install leaf spring clamps.  This set of springs is C4ZA-5556S off of my 1966 Metuchen k-code fastback.
Pic 1:  Clamps used to keep leaf springs straight.  Note the c-clap used on the left to help the leaf spring clamp fit tight to the leaf spring.
Pic 2:  Important:  Clamps will have a two short, two medium, & two long sizes.  Make sure to line these up in correct spot
Pic 3:  Use c-clamp tool to hold clamp in place
Pic 4:  Use soft mallet to start making the bend around the leaf spring.  Then use c-clamps to help make the bend final and tight on both sides of clamp.
Pic 5:  Use soft mallet to bend tabs over.
Post by: J_Speegle on March 17, 2018, 02:51:40 PM
Bob Gaines was surprised that my 67 SJ springs (date coded C7 -- 040) were square.
Since that would be a year specific discussion I suggest a new thread in the 67-8 section. :)
Post by: Bossbill on March 17, 2018, 03:26:27 PM
New thread for 67-68 leaf spring clamp eye changeover date created here:
http://www.concoursmustang.com/forum/index.php?topic=17767.msg112222#msg112222
Post by: dkknab on July 22, 2023, 10:33:10 PM
My leaf spring clamps are the incorrect finish and are missing the rubber grommets. Is it possible to replace the clamps with proper grommets with the springs installed on the car or is that asking for trouble?
Post by: Bob Gaines on July 23, 2023, 12:25:05 AM
Yes it is possible. However since you are concerned about the proper finish of the clamps then it begs the question are the leafs of the springs the proper finish? There is no use worrying about the clamps if the leafs look wrong. If like I suspect that the leaf springs were metal color painted over the springs and clamps you will not be able to make things look satisfactory by adding different clamps. It will look half a$$ done and still be a possible deduction(which I know you are concerned about).  If they are not finished correctly then you best take them out and do the job properly. You can take one side out at a time to refinish if you so choose.
