Author Topic: Air Con Bar Dash Spacer  (Read 2281 times)
Offline 66RavenGTCoupe
« on: May 30, 2016, 10:43:12 AM »
Hi all,
I came across this item on the NPD site. They have a different one listed for both 65 and 66 with a varying lower profile. Was this originally a factory part? I'm asking as my wife's 65 does not have it in her owner installed original 65 air con system. Is it just to fill the gap between the air con register and the dash? Has anyone got any pictures of one installed?
Thanks in advance,
Dan.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Offline 196667Bob
Re: Air Con Bar Dash Spacer
« Reply #1 on: May 30, 2016, 12:09:04 PM »
Dan : If for some reason you have the "earlier" Hang-On (first picture attached), it would not have the spacer (which is really noted as a "Brace"). If you have a 1966 unit, it should definitely have it. If you have a true 1965 unit, I'm not sure. The reason I say this, is that even though the Illustration from the 1960-68 MPC shows the Brace (19C604) as supplied in the A/C Kit only, that number does not show up in the Text Sections of the 1960-68 MPC, the 1965-72 MPC, nor the 1966 MPC. It does, however, show up in the 1966 Electrical Assembly Manual as "C6ZA-19C761-A"(this number did not show up in any of the MPC's, nor in any of the OSI books that I have). This says one of two things to me; either it was not part of the 1965 Kit, or it had a "C5" part number. Hopefully, someone with a 1965 Electrical Assembly Manual can confirm one or the other.
Hope this helps a t least some.
Bob
MCA 04909
« Reply #2 on: May 30, 2016, 04:07:04 PM »
This should help - 6 examples of the 30-40 ones I have pictures of.
Of course one could have been left out if it was dealer installed but that was not apparently the plan or what Ford wanted to happen
Hope this answers your question
Offline JKWilson
« Reply #3 on: May 30, 2016, 04:20:37 PM »
Just to add Dan, there is a difference between the '65 and '66 styles also. The '66 is taller where it spans the top of the a/c unit to the bottom of the dash. If you'd like a pic I'll dig out my '66 spacer (not installed in the car yet).
« Reply #4 on: May 31, 2016, 01:05:51 AM »
Hey Bob,
Thanks. That does help along with Jeffs pics - Thanks once again. the 65 styled one actually looks like the one pictured in your second diagram! - Go figure.
JK Wilson,
I think that for the good of the thread that it would be worth posting some pics of it on here as a separate part. Thanks for offering.
Dan.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline JKWilson
« Reply #5 on: May 31, 2016, 10:58:11 PM »
Here's a few pics of a '66 style for comparison Dan. As you can see the '66 appears to be a slight bit taller (though not much). It is also angled and straight across on the bottom where it meets the a/c unit. The '65 has a contour in the middle of it and (IIRC), was straight up.
« Reply #6 on: June 01, 2016, 06:38:52 AM »
Thanks JKWilson. Thats a very clean AC unit you have there. Coin tray looks great too!
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline JKWilson
« Reply #7 on: June 01, 2016, 08:38:59 PM »
Thanks. I got really lucky with it. I had a pretty nice '65 unit which someone had installed in my '66 fastback...and did it poorly. I was trying to figure out what to do to get a correct unit to install in my '66 coupe. While working one day I met a guy working on his '65 vert in his garage. Long story short, he had a '66 unit (the one you see) and was wondering what to do for his car. The rest is history! ;D
The chrome isn't 100% but it's pretty darn close with just a few small spots. The spacer didn't come with it, but I found an original on Ebay...cheap!
« Last Edit: June 01, 2016, 08:41:25 PM by JKWilson »
