Author Topic: 64 1/2 Fuel Sock Removal from Sending Unit  (Read 1020 times)
Offline FXguy
    • Early 64 June K Convertible Restoration
« on: October 13, 2017, 08:37:49 PM »
I have the original fuel sending unit for my 64 1/2 K code and it works fine, but I noticed a crack in the end of the fuel sock end nearest the pivot.  The filter material seems to be fine (no tears), but I'm thinking of replacing the sock anyways, just to avoid any future problems.  How do you remove the sock and replace?
-Scott
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
Re: 64 1/2 Fuel Sock Removal from Sending Unit
« Reply #1 on: October 13, 2017, 09:04:01 PM »
it just pulls off.
« Reply #2 on: October 13, 2017, 09:20:21 PM »
 I typically twist one way and then the other way all the while putting pulling pressure on it. It can very very tight so you have to put sufficient pressure to get it to move. It should un thread off by doing it this way. It does for me. Sometimes it will crack and self destruct when trying to take it off . If you are lucky it will pull straight off with out much effort.
« Reply #3 on: October 14, 2017, 08:32:52 AM »
Consider using an OEM filter also...
Offline FXguy
« Reply #4 on: October 14, 2017, 12:48:23 PM »
Thanks Bob.  I started with that approach, we'll give it a little effort now that I know there isn't something else holding it on other than an interference fit.
-Scott
Scott McMullen
Offline FXguy
« Reply #5 on: October 14, 2017, 12:50:18 PM »
Definitely, but thus far I have only seen the 3/8" OEM.  This needs the 5/16".  If you've got a source, I'd appreciate hearing about it.
Thank you,
-Scott
Scott McMullen
