Author Topic: Front suspension finish & paint marks - Oct 64 SJ Hipo  (Read 17957 times)
Offline edwardgt350
Re: Front suspension finish & paint marks - Oct 64 SJ Hipo
« Reply #75 on: April 01, 2018, 08:54:13 PM »
1- are the tie rod sleeves clamps the same color/finish as the sleeves?
2- was grease applied to the threads?
3-are the tie rod sleeve bolts/nuts darker in color? would gun bluing achieve the correct darker appearance?
« Reply #76 on: April 01, 2018, 09:39:50 PM »
Both were formed and made from similar steel materials handled much in the same way[/quote]
Would not expect to see any visible grease
Yes you can use gun bluing to darken down the bolts and the nuts to a lesser amount  they were not dark or heat treated
