Marketplace => Wanted Ads => Topic started by: 7Lscjracer on December 08, 2013, 08:35:47 PM
Here's a bunch of stuff I'm looking for in nice used condition mostly or as NOS thanks:
69 hood striker (bolts to hood)
69 early 428 shaker scoop bowl without vent hole and hose holder (have vent type bowl to trade or sell)
8 sealer filled pal nuts 382110-S 9/64" ID, 11/32" OD, 11/32" hex for 4 scoop badges
C9WY-15702-A under hood light assembly with hex head mounting & grounding screws (This is a Cougar item, I have the 68 part numbered version to sell/trade)
69 2 outer low beam 3 prong G.E. FoMoCo script headlights
69 RH & LH back up lamps with part numbers printed on wiring
70 RH & LH dual exhaust muffler floor pan hangers
70 RH & LH stainless steel strips for side windows D0ZZ-6322220/1-A
2 67-69 C7ZZ-6511202-A quarter panel drain vents
5 pinch clip from San Jose plant for rad support to hood rubber seal
69/70 seat belt reminder/warning lower dash bezel and wiring harness
69 am 8-track with knob set, front bracket, rear bracket with stud & nut
69 LH(orn/blk) wiring harness for deluxe door panels equipped with speakers
RH & LH door speakers used original with 8 screws
RH & LH factory door speaker area patch pieces from donor doors
69 remote mirror bezel nut
69 door panel cup RH rubber insert
70 RH & LH door panel cup support brackets
Rear seat side panels uncut for speakers
Group 27 battery tray
67-69 battery J bolts C5AZ-10756-A 8 5/16" OAL
69 battery hold down clamp
428 C9AE-A starter solenoid
69 351W 24" radiator w/ATX
69 RH & LH lower mounting brackets for 24" rad
70 RH & LH lower mounting brackets for 24" rad
Firewall grommet for 69/70 manual choke cable
69 Intermittent wipers assembly
2 67-69 14" beauty rings
Original Door Speakers Here. http://www.ebay.com/itm/1969-1970-Mustang-GT-Mach1-Shelby-Cougar-ORIG-8-TRACK-AM-FM-STEREO-DOOR-SPEAKERS-/151182971718?pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2333351346
I may have some of the parts. I know I have n NOS and a used 27 Battery tray
Pics and pricing for the trays would be great thanks!
You can try to PM me if you prefer.
I tried to do that, but the message doesn't show up in my sent folder!!!???
