1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Shelby => Topic started by: Brian in PA on April 17, 2016, 11:36:06 PM
Hi Guys! Does anyone have any info on a prop rod used for the 67 Shelby? I thought it might be a cool addition to my clone.
Thanks!
Brian
67 Shelby's didn't use one
Still might be helpful/useful
thanks jeff
Jeff,
I understood some early 1967 Shelby's did. There is no vin information in The Definitive Shelby Mustang Guide 1965-1970, written by Greg Kolasa.
On page 131, bottom two captioned pictures; And I quote: "Some early cars used a Falcon prop rod in lieu of springs on the hinges to hold the hood open. Semicircular brackets on the bottom hood and the inner fender capture the ends of the rod."
Is this an error by Mr. Kolasa in his book?
-Keith
Jeff,
Its said that some did. I've never seen one that was original and since the OP was attempting to make his car more like an original I suggest that the prop rod would make more viewers at shows see it as a sign that the car is less like the original - which I think was the purpose. Have pictures of the first 32 67's (missing only a couple) and not one of them has a prop rod
Example - one of the factory drag cars had modified rear wheel wells. Would not suggest that someone building a clone copy that detail
Sure Bob will stop by and provide some additional input
No logical or concrete evidence to support the prop rod observation as factory. Most likely another urban legend perpetuated to justify a non original part on a car. Books can't evolve with new information or conscientious of opinion unless a second updated edition is printed ,and a third,forth ,fifth etc.
The reason I posted what I found in the book is because Greg Kolasa is the co-author of the Shelby-American Registry. I would assume he had noted this, or consulted others in the know to maintain accuracy. It also puts the Registry in question to some extent too, doesn't it? Once again, this isn't questioning you gentlemen, but trying to determine how this kind of misinformation still winds up in print when the writer is who he is and it's listed as a "Definitive Guide".
You would have thought others would have been consulted before this went into print to avoid these kinds of mistakes that we have seen so many times over the years. By the way, I have never seen a real vehicle with a prop rod either.
-Keith
its actually funny. That is where i saw the prop rod at too. I though it was kinda neat and different. Also I am having some issues with hood fitment. With the springs off the hood closes perfect. 8) 8) so the prop rod would be the easy way out ;)
You would have thought others would have been consulted before this went into print to avoid these kinds of mistakes that we have seen so many times over the years. By the way, I have never seen a real vehicle with a pro rod either.
-Keith
There are many authors of the Shelby Amercian registry. They typically have expertise in specific areas. Greg's is more then anything else GT40 and Hertz car documents and statistics. Disregarding that the information in many instances is still evolving as mentioned before,IMO it is reasonable for any of them to be given a pass on a item or two that may not be accurate out of the thousands that are accurate in the encyclopedia size registry book or information taken from it.
Brian, Posted an article on hood hinge adjustment in the Shelby section, as I was having the same issue. The idiot painter aligned the hood without the springs on them because he had misplaced the box with them in it. When I drove the 240 miles to pick up the vehicle I decided not to deal with dropping off the trailer and coming back a week or two later again being I don't own a truck. It was about two months ago and something you will find very helpful if you're suffering from the stink bug effect. 9 Back of the hood sticking up higher than the cowl when you close it.) However, it explains where to start and how the hinges should be positioned for starting the procedure.
-Keith
