1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: fjm on February 19, 2018, 06:07:23 PM
My factory 65 grill is a mess, with some broken and distorted honeycomb I would fix if steel, but can't because it's aluminum. I found a lot of replacement grilles I can buy online and bought one from Mustangs Unlimited. It's only half the thickness of the original stock and very flimsy and bends easily. Does anyone know where I can get a replacement with an original stock thickness?
Your money was wasted on the repro. Only way to go on this part is NOS or good used original.
Yeah. I know. Not the first I've wasted money on.
So far I haven't been able to find either, and it's hard to trust what you find online. Will keep looking.
It shouldn't be hard to find an original grill from a parts car, craigslist, ebay or even find a NOS one from any one of the guys across the country that sell NOS items. Fred Ballard in Canyon City California is a guy I use to buy NOS parts.
be careful of some n.o.s. parts as i have seen them incorrectly finished. you may have to repaint what you find.
+1.Having done a ton of research during the restoration of mine I've seen 66 NOS grilles without the center blackout ,unpainted rivets and even with more modern style rivets.
Ford serviced the '65 grille, later version, with incorrect style rivets. It's a little work to make right, but way better than the repro.
My factory 65 grill is a mess, [and] it's aluminum. It's only half the thickness of the original stock and very flimsy and bends easily.
Just out of curiosity, what was the thickness? I measured mine, it is aluminum too, and it's 0.053-0.055 inch thick on the upper horizontal edge to the left of the latch support bracket.
(As long as I was there, I measured the steel radiator support and it's also 0.053 inch thick.)
Using an old micrometer, my original grille thickness reads about 0.042... the repro is 0.023. Not sure how accurate the micro is but even if it's off a bit the original thickness for sure measures about 2x the repro. Pretty thin and easy to distort. I'm still looking for a good original and will change out the repro if I find one.
As for rivets, I've seen pictures of solid rivet heads that are supposed to be original. Looking again at my old grille, a couple original factory rivets still on brackets have a hole in the center of the head and look exactly like stock Surebonder aluminum pop rivets I picked up at Menards. Side by side, can't tell them apart, though the bottom of the replacements bulge a bit more after install.
Sure learn a lot on this forum. Fun, and aggravating at the same time.
