Author Topic: Oil Pressure Sending Unit Extension  (Read 1983 times)
Offline mikeinvegas
« on: April 13, 2010, 12:28:35 PM »
Hi Everyone,
In reference to this extension and the oil pressure sending unit.
Are both of these pieces supposed to include using "teflon tape" on the threads?
MIV
Re: Oil Pressure Sending Unit Extension
« Reply #1 on: April 13, 2010, 02:12:30 PM »
Hi Everyone,
MIV
No teflon tape was supposed to be used but if you want to use some be sure to take a small steel pick and remove the excess tape from the exposed threads down to a level on the threads where it is less or not noticable. Bob
« Reply #2 on: August 04, 2022, 01:40:46 PM »
What is the finish on this extension?
My guess is bare steel.
« Reply #3 on: August 04, 2022, 03:48:29 PM »
Don't be fooled by service replacements offered decades later that did have white teflon tap on the threads only to about half way up from the base.
« Reply #4 on: August 04, 2022, 06:33:45 PM »
Indianhead brand gasket shellac is similar looking to the product used to seal various fittings etc.back in the day at Ford .
« Reply #5 on: August 04, 2022, 06:47:12 PM »
Got it on the thread sealer.
But is the steel extension just bare steel? Looking for the finish.
« Reply #6 on: August 04, 2022, 07:20:42 PM »
Bill I have always done them in silver zinc.
« Reply #7 on: August 04, 2022, 08:16:47 PM »
Here is an unrestored example that is yet to develop a layer of rust from one of the cars in the Unrestored picture threads. Plating on the extension must have been applied thicker compared to the zinc (dichromate over zinc) on the fuel pump button
Yes some one has removed and replaced and reattached the sender since someone added teflon tape ::)
« Reply #8 on: August 04, 2022, 08:25:06 PM »
Thank you Marty and Jeff.
I went through every "oil pressure extension" (and variants) post I could find and the finish never came up.
Hope it helps others, too.
« Last Edit: August 05, 2022, 11:15:45 AM by Bossbill »
« Reply #9 on: August 05, 2022, 12:44:25 AM »
The extension is plated clear zinc.
The use of Teflon tape MAY not ground the sending unit properly. Use a liquid or paste type sealer.
