1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year > 1969 Mustang
69 Running Changes Main Thread - Dearborn Findings
(1/1)
J_Speegle:
Since we have running changes stickies for other years I figured we need to at least start a thread covering 69 running changes since some have popped up in the past and I'm sure there are plenty more. Will leave the Boss and Shelby specific details for threads in those sections and post the ones that those cars have in common with Mustangs in this one.
Will continue to add suggestions for individual running changes here in this thread while will be the basis for related link threads focused on each individual subject. Remember to keep these 69 Dearborn focused here please not for cars and findings from other plants or years. We can cover those elsewhere. but of course many of these changes too place at the other plants they the change over period may have been different - the reason for keeping them all separate.
To keep the thread from getting too long or out of hand please don't post that you found this version or that on car 9F01T2345xx (for example). We can save that for the research period and for the individual running change threads as we have for other years so far. Just trying to identify the features during this first effort. Will break out the findings by plant of course.  Hope we can work through other plants also. Since this is likely to get to be a very long list I think that unlike the 66 version I will break the lists out by general area of the car to keep it a little more organized. We'll see how that works.
If you post suggestions for items to be included I will delete your posting after it has been incorporated rather than let the add to post run on for pages ;)
DRIVETRAIN-
Engines-
DE1- Belt and pulley changes on small and big block applications built after Oct 10 1968 - According to a TSB Article
DE2- 428CJ Valve Cover Style  - Change from early chrome plated sheet metal valve covers to cast aluminum. Since all engines were were produced and valve covers installed at that time
       the change over at the engine plant would be the same for all plants. MPCs show the change as taking place after 2/14/69 and if this is the date it changed at the engine plant IMHO its likely
       pretty correct date. Might be interesting to see when those were installed at each plant. Will likely have one thread about the engine plant date and see where this leads
DE3-
DE4-
DE7-
DE8-
DE9-
DE10-
Transmissions-
DT1-
DT2-
DT3-
DT4-
DT5-
Rear End-
RE1-
ENGINE COMPARTMENT-
EC1- Engine compartment visible cowl section finish - Early cars were painted  body color above the firewall to cowl pinch weld while later cars were painted engine compartment black. One related thread. Sure we will get to one where the subject focuses on the full year at this plant.
       http://www.concoursmustang.com/forum/index.php?topic=16577.msg103707#msg103707
EC2- Change from flat to reinforced version of the drivers side forward inner fender panel. Survey was conducted and the change over period appears to have been on or between March 25-31 1969 at this plant.
       https://www.concoursmustang.com/forum/index.php?topic=25351.new#new
EC3-
EC4-
EC5-
EC6-
EC7-
EC8-
EC9-
EXTERIOR/BODY RELATED-
Panels that make up make up the unibody or metal panels attached to
E1- Mach I/Sportroof inner quarter window panel -
E2- Hood substructure panel design
E3- Inner fender panel - drivers side forward - Flat verses ribbed
E4- Fixed (non-Shaker) hood scoop cutout -
E5- Mach I side stripes - Non-reflective and reflective versions
E6- Quarter panel extensions/end caps - Plastic/fiber glass verses pot metal. Think this one will take allot of work since it will only personal observations. Not something typical pictures will show.  Change Thread started here -
       https://www.concoursmustang.com/forum/index.php?topic=29484.msg179518;boardseen#new
E7- Mach I Trunk Stripe - With or without MACH I in the center of this stripe
       https://www.concoursmustang.com/forum/index.php?topic=26524.msg163180#msg163180
E8-
E9-
E10-
INTERIOR-
I1- Tire pressure sticker - Various versions used during the production year so won't try and summarize findings here. Current thread lumps all plants together
       http://www.concoursmustang.com/forum/index.php?topic=4427.msg24590#msg24590
I2- Mach I and Grande Interior Woodgrain - Change form what was referred to as Teak to Walnut -
I3-
I4-
I5-
I6-
TRUNK-
T1-
T2-
T3-
T4-
T5-
T6-
UNDERCARRIAGE & SUSPENSION-
US1-
US2-
US3-
US4-
US5-
US6-
Last Updated - 3/18
/24 3PM
