Author Topic: San Jose Door hinge sealer?  (Read 210 times)
Offline jmlay
« on: April 15, 2024, 11:37:03 PM »
Is there a difference in application of sealer around the door hinges between plants? I found the post below, indicating a small continuous bead of sealer on the front and top of the upper hinge, Dearborn. Is this the same for San Jose? Thoughts on the lower hinge?
https://www.concoursmustang.com/forum/index.php?topic=20565.msg129672#msg129672
Mike
« Last Edit: April 16, 2024, 12:11:10 PM by J_Speegle »
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Re: San Jose Door hinge sealer?
« Reply #1 on: April 18, 2024, 11:20:44 PM »
Like Dearborn the upper hinge go sealant on the leading front edge, along the top and rounding around the top rear surface about 1/2" to finish off the pass
No sealant around the lower hinge for some reason
The forward part of one or both hinges could have also received additional sealant from the vertical spray sealant application as shown in the pictures below. Seems pretty common so likely one or two workers of same or different shifts
