1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 - 70 Shelby => Topic started by: 1970shelbyguy on May 02, 2015, 01:17:49 PM
i mounted my orig mesh using some double sided tape given to me by a fellow 69 shelby owner- looks quite thick . is it thick or can i use some thinner stuff
It depends on your definition of thick and thin. Try to use the same thickness as what was used originally . Your original sample should give you your answer unless it has been cleaned off. It was on the thicker side . Report back if you need further confirmation.
i just have a bit left around 1/8" thick.
No thinner then that.
Have pictures of the original adhesive but will need to wait to post until I get access to my pictures in a few days
