1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: preaction on June 25, 2015, 03:47:46 PM
Title: 67 FE starter date code
Post by: preaction on June 25, 2015, 03:47:46 PM
are there date codes on big or small block starters ? thanks Paul.
Title: Re: 67 FE starter date code
Post by: Bob Gaines on June 25, 2015, 03:53:40 PM
Yes. Depending on the time frame and the plant they would be part of the ink stamp and later in 67 switched over to the metal stamped identification and date code.
Post by: J_Speegle on June 25, 2015, 09:18:13 PM
+1
Search turned up this earlier thread ;)
http://www.concoursmustang.com/forum/index.php?topic=9894.msg59369#msg59369 (http://www.concoursmustang.com/forum/index.php?topic=9894.msg59369#msg59369)
Post by: preaction on June 26, 2015, 12:33:53 AM
I did look at that search and I didn't see where the metal stamping would be, C5AF-11131-A on the nose and what I believe to be a ink stamping with a little black paint added on top just for fun.
Post by: J_Speegle on June 26, 2015, 02:34:21 PM
So you saw and read these - all ink stamp related
http://www.concoursmustang.com/forum/index.php?topic=11000.msg66530#msg66530 (http://www.concoursmustang.com/forum/index.php?topic=11000.msg66530#msg66530)
http://www.concoursmustang.com/forum/index.php?topic=9396.msg66611#msg66611 (http://www.concoursmustang.com/forum/index.php?topic=9396.msg66611#msg66611)
http://www.concoursmustang.com/forum/index.php?topic=9894.msg59406#msg59406 (http://www.concoursmustang.com/forum/index.php?topic=9894.msg59406#msg59406)
http://www.concoursmustang.com/forum/index.php?topic=2932.msg15654#msg15654 (http://www.concoursmustang.com/forum/index.php?topic=2932.msg15654#msg15654)
Post by: preaction on June 29, 2015, 06:13:48 PM
I did not find all of those, thank you.  I believe I can see the stamping under a very light spray of black spray bomb, is there anything besides wiping it with a light solvent to remove the black paint ?
Post by: Bob Gaines on June 29, 2015, 06:25:12 PM
If it is metal stamped it will not make a difference if the paint rubs off with solvent because it can be made to look untouched again. If it is a ink stamp don't waste your time tying to save it because it is a lost cause if covered by paint even if only lightly.
Post by: 67gtasanjose on June 29, 2015, 06:30:54 PM
I know that Deadnutson (Jack) does inkstamp for ALTERNATOR rebuilds, does anyone simply do the "INK" stamping on STARTERS?
Post by: J_Speegle on June 30, 2015, 02:45:06 AM
Don't know anyone doing it as a service currently. Heavy items to be shipping back and forth for just a stamp.   Guess you have a blank (not metal stamped) one
Post by: 67gtasanjose on June 30, 2015, 06:33:37 AM
This causes two questions to come to mind.
1.) Does anybody do rebuild services including the date codes?
2.) Is there an easy way to make my own stamp to do the stamping myself.
I'm only slightly off topic, but it fits here too. I DO have a blank-case starter (for a small block, right now it's in working, used condition)
There is nothing preventing me from simply shipping the case alone out to be stamped since it has to be diassembled for the rebuild already. I could have the body already repainted prior to shipping.
Sincce I haven't already ordered parts or taken it apart, I suppose I could become willing to consider sending the rebuilding of the whole starter out if that is the ONLY way to get the stamping done.
I like to do whatever I can for myself whenever possible/practical. If making my own stamp is a practical solution,   I might need at least a clear image with correct numbers for a small block to work with plus an idea of how many days or weeks to pre-date the date code for my project (actual build date 11/2/66)
Richard
Post by: J_Speegle on June 30, 2015, 04:03:38 PM
Don't believe anyone that is rebuilding is stamping/altering date codes in the metal. At least one is redoing the ink style stamp - incorrectly IMHO
No - designing the stamp is not easy and will take approx 20-30 hours depending on how good you are with computer graphic programs and how close to original you want to get.
Post by: preaction on June 30, 2015, 04:08:19 PM
I am curious as to where the metal stamping was applied all of the above (thanks) were ink stamped, Paul.
Post by: J_Speegle on June 30, 2015, 04:57:36 PM
(http://www.concoursmustang.com/forum/gallery/4/6-300615145712.jpeg)
