Restoring - General discussions that span across many different groups of years and models => Processes, Products & Techniques => Topic started by: Angela on December 20, 2015, 04:24:19 PM
Title: Reusable Loctite?
Post by: Angela on December 20, 2015, 04:24:19 PM
From time to time I KNOW I've seen certain fasteners (nothing to do with classic Mustangs) come with a semi-hard blue loctite already applied and those fasteners could be adjusted later. However, Loctite's website is BEYOND useless. Can anyone point me in the direction of a threadlocker that can be adjusted / reused without applying heat? (low to medium strength) It seems like the stuff I've seen on fasteners is more like a semi-hard paste, as opposed to the liquid like in Loctite 243 or similar product.
Title: Re: Reusable Loctite?
Post by: WT8095 on December 20, 2015, 06:44:13 PM
I assume you mean "removable", not "reusable"? Once you've assembled the joint and taken it back apart, you must apply new thread locker. 243 (blue) is a good choice for joints that you want to disassemble with hand tools. Higher strength formulations like 263 require heat to take apart, although I've found that methanol will break it loose without heat.
Loctite's website isn't so bad, you can browse through all the threadlockers here:
http://na.henkel-adhesives.com/industrial/product-search-1554.htm?countryCode=us&language=en&BU=industrial&param1=application%3D00000002AD%7Ckeywords%3D%7Caction%3Dsearch%7Cmode%3Dfaceted%7C (http://na.henkel-adhesives.com/industrial/product-search-1554.htm?countryCode=us&language=en&BU=industrial&param1=application%3D00000002AD%7Ckeywords%3D%7Caction%3Dsearch%7Cmode%3Dfaceted%7C)
They do make 243 in "stick" form, that can be assembled long after application:
http://na.henkel-adhesives.com/industrial/product-search-1554.htm?nodeid=8797900177409 (http://na.henkel-adhesives.com/industrial/product-search-1554.htm?nodeid=8797900177409)
Or, you can always contact a distributor and they will gladly assist you. I work with Ellsworth Adhesives here in the Twin Cities:
http://www.ellsworth.com (http://www.ellsworth.com)
Ask for Erin Stone. She is friendly and very helpful, and if she doesn't have an immediate answer for you, she can get it directly from the Henkel (Loctite) technical reps.
Post by: Angela on December 20, 2015, 08:02:34 PM
Thanks for taking the time to write down a bunch of info for me! :-) I'll try giving your contact in the twin cities a call.
Actually, I did literally mean reusable (not removable). It's a semi-hard paste-like loctite product that I know exists because I've used it. However, I say Loctite's website is nearly useless because I cannot readily locate this reusable product. To be fair (to loctite), I suppose it's possible that the product I'm thinking of is made by one of loctite's competitors such as Permatex.
Post by: drummingrocks on December 20, 2015, 09:29:55 PM
I've got a kit I bought several years ago, it has all of the flavors of Loctite equipped in chapstick/lipstick-style tubes.
Found it, this is what I have: https://www.pegasusautoracing.com/productdetails.asp?RecID=7423
The actual Loctite in the kit is a smearable paste, almost like candle wax.
