Marketplace => Wanted Ads => Topic started by: Fastback2013 on January 27, 2016, 11:35:58 AM
Looking for the RH bracket that fixes the fender to the rocker panel (under) at passenger side.
Hoping that some one can help me further.
Thanks in advance,
Jeroen
Try horseheavn@aol.com he has lots of used parts.
1-509-627-8264 after 9am M-Sat
Troy
For what year Mustang?
Thanks for your reply's!
It's a 67 fastback, built in january (12/01)
Kind regards,
Jeroen
I thought the fender bolted directly to the "T" nut mounted in the rocker panel. There is a small "L" bracket at the bottom of the fender that attaches to the splash shield. There is a fairly flat bracket from the outer edge of the firewall, with a somewhat hidden ender bolt accessed from the door jamb area.
Can you provide a picture of the driver's side so that we can make sure we are clear on the part you are looking for?
