Restoring - General discussions that span across many different groups of years and models => Parts => Topic started by: Andrew@MagMustangs on January 27, 2016, 09:17:47 PM
I'm referring specifically to the metal/black plastic capped units usually used on warning light cars. Not the bell type.
What have you guys/girls seen to identify originals? I don't recall ever seeing any with factory logos.
Any Motor, Any Year 1964.5 - 1973.
Not knowing is something I have never come to terms with. ;)
Caps are multiple different colors sometimes identifying the supplier and or application. Let me dig out some pictures and TSB article to help with some
Have seen factory logos - just not Ford since I don't believe the produced them ;)
I think this is one, isn't it?
Yes for one of the spade connections rather than the post.
Caps are multiple different colors sometimes identifying the supplier and or application. Let me dig out some pictures and TSB to help with some
This is the oil sender on my 1966 San Jose 6 cylinder convert (18K build date), not sure at all if it is original, I hope it is. Could this be an original part?
Maybe Ford did have them stamped when original?
Yes could be the original - there are other versions that are stamped by a sub contractor also depending on year and application
Check the brass base for a stamping ;)
Sending units are usually date-stamped, Month/Year, like 'L5'
The 64.5 style warning light sender is the big stepped version, black. Later, maybe when alternator systems first started being installed is the small slide-on, olive drab. I'm sure there are variants of the small style.
For 66, have mainly seen 'KS' in script oval stamped at the top with a pressure rating, like '80' at the base and date code.
Here are a few pictures from 66 T codes (Deaborn and San Jose examples) Since the engines were all assembled and shipped with the sender installed they should be the same
http://www.concoursmustang.com/forum/index.php?topic=13678.msg84628#msg84628 (http://www.concoursmustang.com/forum/index.php?topic=13678.msg84628#msg84628)
(http://www.concoursmustang.com/forum/gallery/5/6-310516153142-583566.jpeg)
http://www.concoursmustang.com/forum/index.php?topic=12291.msg74730#msg74730 (http://www.concoursmustang.com/forum/index.php?topic=12291.msg74730#msg74730)
(http://www.concoursmustang.com/forum/gallery/5/6-310516153141-58341132.jpeg)
And another example
(http://www.concoursmustang.com/forum/gallery/5/6-310516153140-58331565.jpeg)
